Brake light issue??
Old Sep 5, 2008 | 07:44 AM
EDM's Avatar
EDM
Brake light issue??
You'd think it was a pretty open and shut case right? Its on a 04 S with the 5th brake light mod.
Passenger side brake light will not light, the middle light will still turn on.
Replaced the bulbs, nothing happened.
Double checked the bulbs. nothing.
Removed 5th brake light wires. nothing
Switched the Panels that hold the bulbs from right to left. guess what. nothing
Is the passenger side light fused or something? anyone ever seen this?
the culprit:
Old Sep 5, 2008 | 07:53 AM
BlimeyCabrio's Avatar
BlimeyCabrio
vampire tap cut the passenger side brake wire maybe?
Old Sep 5, 2008 | 08:12 AM
EDM's Avatar
EDM
vampire tap?
Old Sep 5, 2008 | 08:16 AM
BlimeyCabrio
I'm assuming the 5th brake light mod used squeeze-on splice connectors to connect the wires? Mine does.... if so, that can break the wire inside the insulation sometimes... no more circuit...
Old Sep 5, 2008 | 08:26 AM
EDM's Avatar
EDM
i used single strand 14g wire to bridge 1 connector to the other
Old Sep 5, 2008 | 08:49 AM
EDM's Avatar
EDM
Also, the passenger side door lock will not unlock by the key? possibly related?
Old Sep 5, 2008 | 10:22 AM
BlimeyCabrio
Ahhhhhh.... I was confused - you're doing the "jumper" between the brake and fog on your pre-facelift taillights...
Possibilities... broken wire... pushed the wire out of the connector inadvertently... or (horrific worst case) Body Control Module failure....
I doubt the door lock is related... though if your BCM is going out, I guess that's possible....
I'd get a circuit tester (little needle thingy you push into the wire to make contact, with a light and a ground wire/clip) and test the brake wire further up the harness with the pedal depressed - is it getting power? Which would mean problem is at or near the connector. If no power, either you have a break further up the harness, or may have a BCM failure.
Old Sep 5, 2008 | 10:50 AM
volki
Well, the official name for this is "brake light mod", which involves "bridging" the brake light and unused -but intact- fog light using a piece of wire as Blimey mentioned above...
It has been a good discussion whether this is safe or not, since it adds extra 40W to the BC1 module. Some experienced BC1 failures due to this, and some had it since early 2002 with no problems.
Since you already eliminated the blown bulb option, it "might" be the BC1 module. I hope not, because that is an expensive piece.
Search for "brake light mod" and you'll have number of threads to read...
Good luck!
Old Sep 5, 2008 | 11:31 AM
BlimeyCabrio
brake light mod - not mode
Old Sep 5, 2008 | 12:53 PM
EDM's Avatar
EDM
Tested voltage,
Drivers side is at 12v
Passenger side 4v....
Old Sep 5, 2008 | 01:01 PM
BlimeyCabrio
Ewwwwww..... that's not good. That means you have continuity (no broken wire), but the BC1 isn't sending enough juice... Might be worth disconnecting the battery for a while and reconnecting, to see if that resets anything...
Old Sep 5, 2008 | 01:45 PM
volki
Oooppsss... Was typing in a hurry and didn't realize it. Fixed now :D
Old Sep 5, 2008 | 03:18 PM
BlimeyCabrio
Although I bet a brake light ala mode would be tasty.
Old Sep 5, 2008 | 03:27 PM
XSIV SUN's Avatar
XSIV SUN
Blimey, you crack me up!
Old Sep 5, 2008 | 04:24 PM
EDM's Avatar
EDM
can anyone predict how expensive this may be?
Old Sep 5, 2008 | 04:47 PM
frenchie's Avatar
frenchie
If you are referring to the cost of replacing the BC1 add in the cost of having the keys reprogrammed as this is the place where the encryption for the ignition keys is stored.....or the vehicle will not start!
Old Sep 6, 2008 | 06:18 AM
BlimeyCabrio
I've seen $600 installed quoted in other threads here.
Etrain
16
Aug 5, 2024 04:37 AM
W0TM8
Dec 19, 2019 07:50 AM
Terry Gallentine
Aug 11, 2015 03:31 PM
