Suspension Webspokes can I use 5mm Spacers
Old Sep 2, 2008 | 10:39 PM
Derosi's Avatar
Derosi
Can I use 5mm spacers with the stock 17 inch Webspokes. Would this have any adverse affects on handling or increase vibration. I think the Stock offset is 48 so would this bring me to 43. Last question is will the stock studs and lugs work with a 5mm spacer and could the increase actually help handling.
Old Sep 2, 2008 | 11:21 PM
Oxybluecoop's Avatar
Oxybluecoop
I used 5mm spacers with my R98's with the stock lugs with no problems.Just make sure those lugs are torqued.
Old Sep 3, 2008 | 03:32 PM
Derosi's Avatar
Derosi
Where did you find them
The H & R 5mm spacers are not for the 14mm R56 they only work on 12mm R53. Where can I get some 5mm spacers designed for the R56
Old Sep 3, 2008 | 03:35 PM
Oxybluecoop
Pep Boys $8.99 each
Old Sep 3, 2008 | 08:01 PM
scott48's Avatar
scott48
I have 5mm H&R spacers on my R56 with webspokes
Old Sep 3, 2008 | 11:42 PM
ghosthound's Avatar
ghosthound
are you using aftermarket lug nuts?
Old Sep 4, 2008 | 12:04 AM
scott48's Avatar
scott48
I got longer bolts just to be safe
YaTuSabe
Aug 23, 2018 11:41 AM
theblackfalcon
Oct 19, 2015 05:22 AM
NickBchillin
Oct 5, 2015 05:11 AM
GAT
Oct 4, 2015 07:27 PM
Zew2888
Sep 29, 2015 08:49 PM
