Suspension strut tower trimming
Old Sep 2, 2008 | 07:42 PM
smlzilla's Avatar
smlzilla
i just bought a set of megan coilovers ...and I realize that the strut towers need to be trimmed a bit in order to gain full adjustability for the integrated camber plates.
I'm a bit hesitant in cutting off pieces of my car .... Does anyone here have pictures to illustrate what kind of cutting is required for this sort of setup? or is there any way to adjust the bolts so i dont have to trim the strut towers???
anthony
Old Sep 2, 2008 | 08:14 PM
AutoXCooper.com's Avatar
AutoXCooper.com
I know it's been done and there are pics on NAM somewhere, I just hope someone can find and post them here. It's just trimming a little bit out of the round sheet metal. You may also want to try a ball Allen tool which some have found gets more neg camber without cutting sheet metal.
Old Sep 2, 2008 | 08:20 PM
smlzilla's Avatar
smlzilla
"You may also want to try a ball Allen tool which some have found gets more neg camber without cutting sheet metal." what is that?
Old Sep 2, 2008 | 08:27 PM
AutoXCooper.com
My bad, it's called a "Ball End" like this, http://www.sears.com/shc/s/p_10153_1...0P?vName=Tools
Old Sep 2, 2008 | 08:34 PM
kurvhugr's Avatar
kurvhugr
Here's a pic of mine.
Old Sep 2, 2008 | 08:36 PM
smlzilla's Avatar
smlzilla
and where does that connect to? i just hope i can get atleast -2.5 camber up front with out any trimming if not then i guess i have to do some trimming...
if anyone has pics of the trimming and write up of the trimming and a write up how to adjust with out the trimming ...
thnx dustin
Old Sep 2, 2008 | 08:37 PM
smlzilla's Avatar
smlzilla
the the setting of your camber? did you trim any? thnx
Old Sep 2, 2008 | 08:54 PM
kurvhugr's Avatar
kurvhugr
Yup, that's definitely trimmed. I wanted to trim as little as possible, so it probably looks pretty normal until you compare the pic with your own towers. It's been a few years now so I can't remember exactly, but I think you'll find the opening at the top of an untrimmed tower raises up like mine and then flattens back out sort of parallel to the top of the tower. It's hard to explain, but the flat top part that's parallel to the top of the tower is all that's trimmed from mine.
That's an old pre-alignment pic taken right after the trimming was done. I think I'm at -2 now (can't remember for sure just this minute) and could go a bit further before needing a ball end allen.
Old Sep 2, 2008 | 08:56 PM
AutoXCooper.com
I found it, see page 32-37 of the below attachment
File Type: pdf
Old Sep 2, 2008 | 09:28 PM
smlzilla's Avatar
smlzilla
hmmmm... interesting....
Old Sep 3, 2008 | 04:21 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
I think Cor Blmy's trimming is pretty standard for adjustable camber plates. Mine look exactly the same, only in Dark Silver !!
Old Sep 4, 2008 | 08:02 AM
etalj's Avatar
etalj
https://www.northamericanmotoring.co...ber+shock+more
Old Sep 4, 2008 | 04:56 PM
///ACS330Ci's Avatar
///ACS330Ci
Pretty clean What did you use to do the trimming?
Old Sep 4, 2008 | 07:52 PM
kurvhugr's Avatar
kurvhugr
dremel w/ cut-off wheel + angle grinder + file
patsum
26
May 29, 2021 06:29 PM
M7Speed
Sep 4, 2015 10:47 AM
Suspension Products
Sep 3, 2015 09:41 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
M7Speed
Sep 3, 2015 07:27 AM
