Suspension Megan Racing R56 Prototypes
Old Aug 28, 2008 | 07:59 PM
scruffylooking's Avatar
scruffylooking
So, I went over to Megan Racing today to have their R56 prototype coilovers installed. Cyrus, they're head tech/R&D guy/pro driver met with me to do the install. Everything fit fine but it looks like the strut bodies are too long. The front's not bad. As you can see in the pictures, it's decently low. I've got maybe .25" more to go down. The rear didn't lower enough. I think this, pictured way below, is as low as it goes. So they're going to order up some shorter strut bodies, front and rear.
As I said earlier, fitment was a piece of cake. The ride is smooth but not as smooth as stock (base MCS suspension). I think that's to be expected. There's a tiny hint of bounciness in the rebound but it's not annoying. No noise from the suspension on the initial shakedown cruise of an hour of LA/OC traffic.
More to come as I get more time on these puppies and, of course, updates to follow after the new shorter struts go in. Alignment and corner balance to occur some time after the set up is finalized... whenever that is.
EDIT: Admittedly, I'm a suspension noob. So, if you have questions, I'll do my best to answer or ask Megan for the answer. If you also have a request for me to test this set up in a specific way, let me know. Finally, if you're in the OC and want to meet up for a test ride, I'm game, too, if we can make the timing work.
Pics!
One front (r) and one rear (l) c/o.
Top of the front c/o.
Rear installed.
Front installed.
Rear Megan next to rear stock. Note that the Megan is wound all the way down. So the body will be shortened for round 2 of prototype testing.
The final results. Not too shabby. I wouldn't go lower in the front but would in the back. The final kit should allow a little more drop in the front and quite a bit more in the back. Not parked on a flat surface. I'm dumb.
Old Aug 28, 2008 | 08:01 PM
scruffylooking
Dang it. Can a Mod change my title to "Megan Racing R56 Coilover Prototypes"? My bad. Then delete this second post. Gracias.
Old Aug 28, 2008 | 08:24 PM
AutoXCooper.com's Avatar
AutoXCooper.com
Thanks for working with Megan on this, I look forward to offering them to NAM Members ASAP.
Old Aug 28, 2008 | 08:26 PM
user 7082082's Avatar
user 7082082
Hey ! I seen you up mulholland drive. The Mini is looking great man.
Old Aug 28, 2008 | 08:32 PM
scruffylooking
Yeep. I'm willingly offer up my car as the guinea pig for the good of the community. Haha.
It seemed like Megan had them sitting around waiting for a sucker like me to stroll by.
Really? Maybe not me? I don't think my car has ever been to Mulholland... I'm usually in the OC. LA is smelly.
Old Aug 28, 2008 | 08:55 PM
danielo's Avatar
danielo
When u install the rear coil. did you have to remove the rear inner quarter panels?
Old Aug 28, 2008 | 09:06 PM
scruffylooking
NOPE!
You can do it all from the exterior. But, the c/o adjustment is at the top of the strut so basically, I'm never adjusting it. Cyrus talked about flipping it so the adjustment was at the bottom but his concern was that struts set up like that aren't as durable. But, it's easier to change your settings. It's a trade off. What would ya'll rather have?
Old Aug 30, 2008 | 04:43 PM
Ryephile's Avatar
Ryephile
My first round of questions:
*How much total stroke?
*What kind of bumpstops and how big?
*Are the dampers still linear damping?
*They now come with rear mounting hats?
*What spring ID is used
*What spring rates are available?
*On your R56, please measure ride height from the apex of the wheel arch to the ground on all 4 corners [on level pavement please]. From the look of your car I'd guess somewhere in the range of 24.0" front and 24.4" rear. Let me know the specifics.
Old Aug 30, 2008 | 08:44 PM
scruffylooking
Give me a few days to work on that. But I'm on it...
Old Sep 9, 2008 | 11:00 AM
scruffylooking
Sorry for going dark for a few days on this. I'm going to hold off on the measurements and answers until next week. I'm getting the revision 2 prototypes installed this Friday and there's no sense in giving you data on an obsolete version.
Old Sep 9, 2008 | 06:34 PM
Ryephile's Avatar
Ryephile
No prob, better to get them right the first time than mess with re-work!
Old Sep 18, 2008 | 05:00 PM
eg0911's Avatar
eg0911
any news on how they fit? also do you know when they are expecting to release them, i sent them a email but no response yet
Old Sep 18, 2008 | 09:56 PM
scruffylooking
Hi all, new ones are in, but I've barely driven on them. Had a, uh, mishap that cracked my intercooler. I was leaking boost so I let the car sit for several days until I got the new i/c. Just put that in last night. I'll drive her out tomorrow and shoot some pics, take some measurements, etc. Thanks for your patience.
Old Sep 19, 2008 | 05:43 AM
AutoXCooper.com
That's great news, thanks for the updates. I look forward to adding them to my site ASAP.
Old Sep 19, 2008 | 08:52 AM
don@baycats.com's Avatar
don@baycats.com
They look like my BC units- different anodising colours Don
Old Sep 20, 2008 | 01:33 PM
eg0911's Avatar
eg0911
Originally Posted by don@baycats.com
They look like my BC units- different anodizing colors Don
from what i have read from other forums, mainly for subarus, megan is just a re branded bc coilover. bc is the original company out of Taiwan and there are many different brands that just stick their name on it and change the color
p.s. finally got a response from megan on a release date, they said within a month or 2 they will be releasing them. they said to check the front page of their website
Old Sep 20, 2008 | 04:04 PM
scruffylooking
Hi everyone,
Busy over here. Slowly getting around to sharing feedback.
Here are two pics for your enjoyment.
Dumped to the bottom of the coilovers. Pretty sure this is as low as it goes. If I'm wrong, I'll report back.
A little night time shot that I snapped last night.
Brief ride report:
At this height, that little lip that hangs off the bottom of my front bumper scrapes on everything. But the ride is relatively smooth and controlled. I'm coming from the base stock S suspension, which I felt was pretty firm to begin with, and this feels only marginally firmer.
Old Sep 20, 2008 | 04:19 PM
scruffylooking
All this is pretty preliminary and subject to change. I fear some of this may be lost in translation, too, since I'm not very technical when it comes to car suspension.
The tech I worked with wasn't positive but he guessed approx 93m in the back and 100-110mm in the front.
Rubber in my prototypes. Probably polyurethane in the production versions.
Do you mean the springs? Springs are linear.
Yes, pillow ball mount all around, steel top plates.
62mm
Mine are 7K in the front, 6K in the back. Production will have more available. Not sure what, yet.
With revision 2: They put new dampers into the rear and changed all four springs from the straight kind, shown in my pics above, to the barrel shaped kinds (skinnier on the top and bottom, wider in the middle). The claimed they did that in the name of ride quality. I think it made a difference for the better.
FR: 24.0
FL: 24.0
RR: 24.5
RL: 24.3
I'm a leetle bit crooked!
Old Sep 22, 2008 | 01:20 PM
Ryephile's Avatar
Ryephile
Thanks for the info! If they do have the damper stroke you think they do, that'll mean they'll have ~4" of wheel stroke front and rear, which is a bit more [and better] than the BC's for the R53.
By linear damping I did not mean the springs, though thanks for letting us know they springs are linear. My question was regarding the damping curves for the dampers themselves; rebound and compression damping can be plotted on a unit-damping vs. velocity graph; I'm just curious if they're linear in both compression and rebound just like the R53 Megan dampers. Stock dampers are mildly digressive, which means low speed damping is higher than high-speed damping. This offers improved ride quality while still having good transitional competence.
Cheers,
Ryan
Old Sep 23, 2008 | 12:50 AM
scruffylooking
Ryan,
I'm going to have to get back to you on... uh... that. Haha.
Let me see what the Megan guys say.
Old Nov 6, 2008 | 02:25 PM
AutoXCooper.com
Here's a updated pic of an R56 on the production Megan Coilovers.
The R56 in picture is lowered and has about .5 inch more drop in the rear and the front have .75 inch more drop left in the system. I think the word we are looking for is SLAMED!
Old Nov 6, 2008 | 11:39 PM
scruffylooking
Hey, that's my car! Here are a few more pics:
Oh, and Ry, sorry for never getting back. Life got in the way.
Now, all I need are some new wheels.
Hippiehobbit267
Dec 3, 2019 04:22 PM
Jan 4, 2019 12:51 PM
Da_jesus
Aug 25, 2015 04:20 PM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
