R52 HORRORS... Say it isn't so
Old Aug 15, 2008 | 03:33 PM
gbtr6's Avatar
gbtr6
Someone at the local BMW shop said that the engine in our 05 Cooper S is the same as the Dodge Neon SRT/4. NOOOO... I assumed it's a BMW sourced motor. Not a Dodge.
Perry
Old Aug 15, 2008 | 03:45 PM
AutoXCooper.com's Avatar
AutoXCooper.com
From, http://www.netcarshow.com/mini/2005-cooper_convertible/
"The MINI One, Cooper and Cooper S use a Brazilian-built Tritec engine while the MINI One/D uses a Toyota-built diesel engine. In August 2006, BMW announced that engines would in future be built in the UK, making the car essentially British-built again (as well as the final assembly at Cowley, the body pressings are made in nearby Swindon)."
They build engines for more then a few cars/trucks.
Old Aug 15, 2008 | 03:46 PM
Mishka's Avatar
Mishka
Not sure about the Neon, but the motor was a joint by project by BMW and Chrysler and was originally also going to be used in the PT Cruiser. Chrysler ended up backing out of using it, though.
Old Aug 15, 2008 | 03:49 PM
MarcoEsc's Avatar
MarcoEsc
Well, if wikipedia is to be believed, it ain't so.
On the Dodge Neon SRT/4:
Engine details
The SRT-4 used an identical block as the naturally aspirated Chrysler 2.4L block used in the PT Cruiser and mid-size cars such as the four-door Stratus. Both naturally aspirated and turbo engines (PT Cruiser GT Turbo and SRT-4) used the same cylinder head with the exception of the Iconel exhaust valves. The PT Cruiser Turbo engine package differs from the SRT-4 because the intake manifold, turbocharger plumbing and intercooler are different. The SRT-4 intercooler was a front-mounted cast aluminum 8-row unit produced by Valeo. The turbocharger was a reverse rotation Mitsubishi TD04LR-16Gk with a 6 cm² turbine inlet. Tight packaging forced some creative thinking on the turbocharger. The TD04 compressor has a compressor bypass valve built right into the compressor housing. The exhaust manifold and turbine housing were cast in one piece by Mitsubishi from high-nickel Ni-Resist steel. The one-piece design improved flow, reduced size and reduced thermal mass for quicker cat light-off. The turbine discharge was also part of the manifold/turbine housing casting, and it looped back around and hit the manifold again on its way to the catalytic converter. Where they met, there was a wastegate valve; keeping the wastegate valve away from the turbine housing improved flow where it mattered most. Maximum boost in stock form was around 14 psi (97 kPa). The stock turbine forces a rev limiter setting of 6240 rpm, although actual engine redline occurs at 6000 rpm (6500 rpm with Mopar Stage 2 or 3 upgrade).
I know that's not what's in my '05 MCSc
Old Aug 16, 2008 | 08:13 AM
STLMINI's Avatar
STLMINI
I believe the two engines share a common block.
Old Aug 16, 2008 | 08:18 AM
ninjlao's Avatar
ninjlao
Ninja Mini
i believe our engines are shared by neons in europe
Old Aug 16, 2008 | 10:33 AM
rkw's Avatar
rkw
2.4 liter engine
We can only dream... This from allpar.com:
Acceleration figures (bone stock): 2003 models
Car and Driver Magazine: 0-60 in 5.6 seconds, top speed 153 mph
Sport Compact Car Magazine: 0-60 in 5.8 seconds, quarter mile 14.2 seconds.
Brooke McClelland wrote: According to their chassis dyno, this Neon puts out 223 HP and 250 lb-ft of torque at the wheels! ... In comparison, their test of a 2002 Nissan Sentra SE-R, which is rated at 175 HP, put out just 141 HP at the wheels. Apex Technology has dynoed the SRT-4 and found 248 hp - at the wheels!
Old Aug 16, 2008 | 10:53 AM
Jtrem's Avatar
Jtrem
Neon engine is 2.4L and the mini engine is 1.6L. I'd say the engine is different. I believe the Euro version Srt-4's engine fits in the Mini. But does it really matter? Who cares who makes the engine. It works obviously.
Old Aug 16, 2008 | 12:01 PM
PGT's Avatar
PGT
or, we can build and get along just fine
Old Aug 27, 2008 | 04:15 PM
jmduke3's Avatar
jmduke3
I am a former SRT-4 owner. I can assure you that the Mini motor and the Dodge motor are no where near close. Though stuffing the 2.4L Turbo in there would be fun as hell! 230hp/250tq in a Mini...add Stage 1 and Wastegate Actuator....
The Dodge motor was based off of the turbo Stratus (yeah, I said Stratus) that was only available for sale in Mexico. The SRT-4 motor was still built in Mexico in fact, the tranny from Syracuse and assembled in Illinois.
Old Sep 4, 2008 | 01:24 PM
Bebedo26's Avatar
Bebedo26
Who builds it?
For the 1st generation of Minis:
In Portugal and Greece, the Mini One was powered by a 1.4 litre I4 version of the Tritec engine but all other petrol powered Minis used the 1.6 litre I4 version.... The "Mk I" Mini One, Cooper and Cooper S used a Brazilian-built Chrysler-designed Tritec engine, while the Mini One D used a Toyota-built diesel engine.
The new version is built by Peugeot:
"Mini introduced a new, second generation of the car for the 2007 model year, Mk II Mini (or R56), on a re-engineered platform with many stylistic and engineering changes. The engine architecture is shared with PSA Peugeot Citroën and is intended to be more cost effective. The engineering was done in the United Kingdom by BMW Group UK Engineering, in Munich, Germany at BMW Group HQ and with external third parties."
Further:
As for engines, the Tritec engine has been replaced in the Cooper model with a 120 bhp 1.6-litre Prince engine with BMW's Valvetronic infinitely variable valve timing, developed on and with Peugeot's core engine. From 2008, all Mini models are equipped with BMW EfficientDynamics fuel-saving technology. This includes a start-stop feature shutting off the engine when the car is stationary (this is not available in 2008 Mini Cooper in the US market). When the gas pedal is depressed the engine is restarted with electricity generated from Brake Energy Regeneration.
And finally -- if you want to be really excited about a Diesel version:
The Cooper D model attains 74.0 mpg–imp (3.82 L/100 km / 61.6 mpg–U.S.) and emits 104 g of carbon dioxide per kilometre.
-- For those of you, like me, "challenged" by conversions, I saw statistics showing 60 mpg urban and 80 mpg extra-urban.
Old Sep 4, 2008 | 02:14 PM
matty125's Avatar
matty125
As far as I know, there is no neon ineurope except those owned by americans working for uncle sam. Ive never seen a foreign owned one in 5 years of autobahn cruising
Old Sep 4, 2008 | 03:09 PM
AKIndiMini's Avatar
AKIndiMini
Um, when I was in Europe last year for just over 3 weeks - I saw plenty of Euro-spec Neons. They call them "Chrysler Neons" over there. They look pretty much the same, except for different tail lights and the rear bumper has a larger indentation in it for the long Euro plates. The 2nd gen also had rear fog lights built into the bumper.
Strangely enough, I saw a bunch of "Chrysler Voyagers" and Jeep Cherokee/Grand Cherokees too. Most of the ones I saw had diesel engines.... *jealous*
Old Sep 4, 2008 | 06:15 PM
Bebedo26's Avatar
Bebedo26
Neon --> Calibre
The Dodge Neon has been rebadged to the Calibre.
Same difference.
I still would rather have my corneas excoriated with sandpaper than drive one.
Old Sep 4, 2008 | 06:33 PM
Dr Obnxs's Avatar
Dr Obnxs
If you've ever driven a Neon SRT/4
or ACR version, you wouldn't be so mad..... But some of the above posters are correct, it was the european Neon that got the same block. Don't know about the rest of the engine though. Take the Mini badge off the top of the valve cover, and there's a very generic 1.6 l cast into the cover.
Matt
Old Oct 3, 2008 | 08:36 PM
BlueBonnet's Avatar
BlueBonnet
Here is an article from March, 2008: Chrysler LLC has signed an agreement to transfer full ownership of Tritec Motors Ltd. to Fiat Powertrain Technologies (FPT). The purchase includes the facilities, manufacturing unit, production lines and the license to produce the current range of products.The Tritec Motors plant is located in the town of Campo Largo in the Curitiba metropolitan area, in the southern Brazilian state of Paraná.Chrysler and the BMW Group established Tritec Motors in 1996 between to manufacture 1.4- and 1.6-liter four-cylinder gasoline engines. The Tritec name stands for the union of the three countries involved: Germany, the United States, and Brazil.The gasoline-powered, four-cylinder, 16-valve 1.6- and 1.4-liter engines were destined for export, formerly equipping all BMW MINI models worldwide; the Chrysler PT Cruiser in South Africa, Europe and other foreign markets; and formerly, the Chrysler (Dodge) Neon sold outside North America.
RobbyD
Jan 29, 2019 01:22 PM
SJ-R50
Oct 28, 2015 08:39 AM
potterstein
Oct 1, 2015 07:10 AM
micromini234
Sep 30, 2015 07:36 PM
Huskyfan
GP Talk
Sep 28, 2015 06:08 PM
