D Stock Exhaust Options For G-Stock
Old Aug 15, 2008 | 10:41 AM
foreverfadesx's Avatar
foreverfadesx
What are my after market exhaust options for G-stock? Is Invidia? I know it eliminates a CAT though....
Old Aug 15, 2008 | 03:57 PM
JustGo4It_'s Avatar
JustGo4It_
Check this thread out.
https://www.northamericanmotoring.co...ght=supertrapp
Old Aug 15, 2008 | 10:30 PM
foreverfadesx
Hmm I'm a bit confused... I want a full exhaust system I can buy like an alta or Invidia. It's for an R56 Cooper S. Are those legal for G-Stock?
Old Aug 15, 2008 | 11:27 PM
OasisT's Avatar
OasisT
I personally like the QuickSilver exhaust. Since you have to cut the stock exhaust at any point of your choosing after the 2nd cat, the QuickSilver exhaust will slip right on with no alterations just after the resonator(QuickSilver comes in 2 pieces, I bet they would sell just the rear piece, thats the only piece I used during the install since the front portion eliminates the 2nd cat and resonator and isn't legal). This allows for a great sound without that annoying drone and the best part is its very lightweight and makes good power.
Not that I am biased with QuickSilver or anything, they have sponsored me for the last 2 seasons in SCCA Solo and are very supportive of our sport.
Old Aug 16, 2008 | 08:21 AM
foreverfadesx
Sorry for all the questions but for an R56 I can install as long as I cut it behind the red circle (see attached photo)? That will be legal for G-Stock? If you don't mind also could you send me a list of the set up on your G-Stock R56? I'm new to autox in the mini so I'm trying to muddle through setting up the car. Thanks!
Old Aug 16, 2008 | 01:30 PM
L8Apex's Avatar
L8Apex
That red circle is the resonator, actually. It's legal in GS to remove that. So you can use the entire QuickSilver system, so long as the entire system has 2 cats.
Old Aug 16, 2008 | 09:21 PM
OasisT's Avatar
OasisT
Actually thats partially correct. The red circled area is the resonator, and, you can legally remove it. However, you cannot use the entire QuickSilver system since the front portion of the system replaces the cat, which is the canister just to the left of the circled piece. The rear portion of the QuickSilver system is what i chose to use(rather than cutting/splicing part of the front system to remove the resonator). If you cut exactly at the correct point(by measuring carefully) after the resonator, the rear portion of the QuickSilver slips over the stock pipe and the QuickSilver uses the factory hanger points. The exhaust shop had mine installed in about 20 minutes with no rattles/leaks. Its unbelievable that the rear piece on the QuickSilver happened to be just after the resonator and it happens to slip onto the stock pipe. I am not sure if they planned that or not, I would assume not, so, it just happens to work perfectly.
Old Aug 16, 2008 | 09:26 PM
OasisT's Avatar
OasisT
Oh, just to clarify, cutting after the circled area is indeed legal, you could also cut to the left of the red circle if you so choose but not to the left of the Cat to the far left. I would recommend contacting QuickSilver to see if they will sell you just the back portion of the exhaust and splicing it in after the resonator unless you really want to remove the resonator(which is OK, but, it will be a bit louder and only a couple pounds lighter).
As far as G-Stock setup, sure, I will PM you all the details. I remember when I first started running GS, Garfield was extremely helpful and gave me mucho info so I try to do the same for those in need.
Craig
Old Aug 17, 2008 | 03:38 PM
foreverfadesx
Awesome! Thanks so much. In the NYRSCCA there's no one who is there consistently with Minis so I'm a bit of a loss.
Old Aug 23, 2008 | 07:07 PM
ken o's Avatar
ken o
Does the Quick Silver really make 35HP?
Old Aug 24, 2008 | 04:30 PM
JustGo4It_'s Avatar
JustGo4It_
Maybe on the space shuttle...... 3-5 sounds more realistic.
Old Feb 2, 2009 | 09:52 AM
cosmosmpower's Avatar
cosmosmpower
Bringing this one back. Was at a Mini tech day at the local dealer and was speaking with one of the dealer techs. We had the car up on a lift and were discussing the stock exhaust system.
He was adament that there is only 1 cat on the car and that the canister to the left is also a resonator. He pointed out that a CAT has to have at least 1 O2 sensor before or after to monitor emissions. Any truth to this? If so it seems like you could bolt some of the entire systems on without cutting where the first cat meets the flex pipe.
Old Feb 7, 2009 | 12:14 PM
FLKeith's Avatar
FLKeith
Strange. I have seen many references to there being two cats but I am not an expert. Here is the installation instuctions for the Alta cat-back clearly showing that they think there are two cats:
http://www.altaperformance.com/share.../ampext130.pdf
Old Feb 7, 2009 | 05:13 PM
L8Apex's Avatar
L8Apex
Yes, there are two cats. One directly in the downpipe and one under the car.
Old Jun 10, 2009 | 08:01 AM
IanF's Avatar
IanF
I'm no expert on the R56 either (and only marginally better on the R53), but I also know from experience that MINI techs often don't know these cars as well as you would think...
Teh
Aug 22, 2022 04:37 AM
WestfaliaR
Aug 19, 2015 08:01 AM
Aug 12, 2015 01:24 PM
papawhiskey
Aug 10, 2015 09:31 PM
