2004 JCW tires & wheels
Old Aug 12, 2008 | 09:33 AM
Gary L. Wilcoxon's Avatar
Gary L. Wilcoxon
I have a 2004 Commemorative JCW, with 21k mi. I have bumps on my front tires side walls of the Goodyear run flats. Goodyear wants me to change to All Season F1's while they analyze my run flats. I would like to change my wheels, for there is some corrosion on the alloy between the 2 pieces. Without effecting the cars handling & tire pressure system, what is the best way to go for tires & wheels
Old Aug 13, 2008 | 09:52 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
For Goodyear F1 All Season tires use the stock 205/45-17 size.
If you want to replace the wheels then look for 17x7 or 17x7.5 with +42 to 45mm offset.
You also have the option for Goodyear F1 GS-D3 summer tires (assuming you don't get really cold weather and snow) in 215/45-17. This size will fit and work fine.
Old Aug 13, 2008 | 06:13 PM
Gary L. Wilcoxon
Tire Presure system
Thank You for the reply, was very helpful. now I was curious about the tire pressure system, mine is one that indicates low pressure, if I change wheels what will be necessary.
Old Aug 16, 2008 | 06:44 AM
Alex@tirerack's Avatar
Alex@tirerack
An 04 would have ABS based TPMS. You dont need to do anything, but run 4 tires with the same diameter. Its ABS counter registers the tire's rotation.
Direct TPMS came a few years later
Alex
Colt45Magnus
Sep 7, 2015 10:47 PM
Mini'mon
Aug 16, 2015 04:15 PM
nomar116
Aug 9, 2015 09:42 AM
PatrikKN
Aug 5, 2015 09:10 PM
