Suspension atla sway bar problem
Old Aug 10, 2008 | 11:32 PM
dandennis123's Avatar
dandennis123
ok so i installed a 22mm rear sway car today and it makes a clunking sound what could it be? i checked everything and im thinking that the sub frame need to be torqued down more cuz i used a ratchet to titan everything.
Old Aug 11, 2008 | 07:01 AM
quikmni's Avatar
quikmni
It could be the end link rubbing on the trailing arm. It might not rub with the car jacked up so you will need to look with the car on the ground. If it is rubbing, it is very important to correct so it does not jam up and cause massive oversteer.
Old Aug 11, 2008 | 07:03 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Could also be a loose endlink.....those things have a way of never tightening enough and then making a bunch of noise while you drive.
I'd jack the car back up and check all the nuts and bolts that you worked with. My guess is that one or two of them are just a little loose.
Old Aug 26, 2008 | 12:42 PM
quikmni's Avatar
quikmni
dandennis123,
Did you figure out what was causing the clunking?
Mini7
Feb 2, 2016 07:52 PM
minimofo
Sep 9, 2015 10:29 AM
Bea5tMa5ter
Aug 27, 2015 01:42 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
