i bought a alta intake tube from another nam member and it has two holes....which im guessing is the auto....will this one still fit a manual if i block off one of the vac holes?
The hole on the side is normal on the manual version. Look at your oem tube and you will see a breather of some sorts goes into the side. Install it just as your oem one was.
