Suspension anyone make springs to lower .75" f and r?
Looks like H&R sport is about 1.0", Tein H-Tech is a bit over .5", anything in between?
I have searched a ton of these threads but can't seem to find any. I just don't think I want to go a full 1.0", but .5" might not be enough or worth it.
I do not think anyone makes them as stock, but most companies will do a "custom" job for you and it should not be too much extra $$$
But, you do have to remember...once installed they will settle in and the drop varies per car...so maybe a .5" spring will compress once settled to a .75" drop...just something to think about and research...see which springs settle the most and which ones stay true
I was just about to come back and suggest the TSW springs...I believe that you are correct with the drop...and I think that is exactly what you(rodH) are looking for
They do not appear on the site right now(they are out of stock) So give them a call and talk to them. They are great guys who go out of their way to help you
They probably will be more though...Check with morristownmini and the BMW Store in Cincinnati, Ohio(they match Morristown).
TSW would be my choice though...
I went with TSW's and the drop looks perfect. Its not so low that others can necessarily tell that is lowered, but low enough for you to notice. High enough to not worry much about ground clearance or scraping, and the ride actually feels a bit better then stock.
melscoop
Mar 30, 2016 06:56 PM
yukinoinu
15
Aug 24, 2015 09:20 AM
