R56 Tire Pressure
Old Jul 28, 2008 | 07:16 PM
MrTIer's Avatar
MrTIer
Tire Pressure
Newbee here - What tire pressure will give me the longest tire life on 17" run flats and what mileage can I expect on the first set with typical driving (50/50 city hwy)?
Old Jul 28, 2008 | 07:37 PM
orangecrush's Avatar
orangecrush
Can't tell you the mileage but I'm running 35psi on mine. If you look in the manual, it starts off at like 32psi and goes up from there as you put more people in the car with more luggage. (I think it finishes off at like 36psi)
Within reason, the more air makes the tires harder (firmer) and create less rolling resistance.
Assuming you're not over-inflating them (it will wear out the centers) they will give you better gas mileage with higher pressure.
Mark
Old Jul 28, 2008 | 07:43 PM
chiliredr56's Avatar
chiliredr56
I run 34 pounds front and rear . I have 8,000 miles now . Rotated at 5,000 . Even all around and look new still .
Old Jul 28, 2008 | 08:29 PM
mellowmcs's Avatar
mellowmcs
the sticker on the door jam says 37psi for under 100mph.
Old Jul 28, 2008 | 10:20 PM
orangecrush
Ys, but that is for GVW... GROSS VEHICULAR WEIGHT... anotherwards, completely loaded.... full gas, full passenger, full luggage.
Mark
Old Jul 29, 2008 | 12:18 AM
Robin Casady's Avatar
Robin Casady
For the MCS with four passengers and luggage the manual says 36 psi for speeds under 100 mph, or over 100 mph with two people.
With one person, 36 psi seems to give a pretty stiff ride. For one person under 100 mph, I would think you could go down to 34 or 35 psi.
Old Jul 29, 2008 | 01:21 AM
Ju5tin's Avatar
Ju5tin
I picked up Bridgestone RFT's and they told me to run them on 38PSI! I run my fronts on 37 and my rears on 35.
Old Jul 29, 2008 | 05:49 AM
army scope jockey's Avatar
army scope jockey
38 psi all around but then again over 100 mph on the Bahn the ride is fine.
Old Jul 29, 2008 | 06:01 AM
JCR1960's Avatar
JCR1960
I've been running 36 psi cold tire pressure all around on my 17" Dunlop RFT.5600 miles with even tire wear so far.I might bump up the tire pressure to 38 psi but if the ride is too firm at that pressure I will back it down to 36 psi again.
khumpert
Nov 30, 2015 11:48 AM
oldkid6
Aug 30, 2015 08:28 AM
TJANK
Aug 24, 2015 06:11 PM
nomar116
Aug 9, 2015 09:42 AM
