R50 JustaCooper plus a Jan Tune equals...
On July 12 2008 I hosted a Tune event with Jan of RMW in Chicago.
I was the only R50 that day.
Your results my vary.
The HP and TQ numbers did go up. The numbers are not really the real gain.
I drove in with a full tank of gas and drove that tank out HARD and still got 30 MPG best every on a hard driving tank of gas.
I don't understand what Jan does to the ECU but it works.
I have a K&N Typhoon, Megan Catback and TSW Damper and thats ALL.
1st impressions were easy to feel. Throttle response is NOW
NO Lag at all and under speed the pedal begs for more. It's a great feeling.
I could always chirp 2nd gear, but now it barks like a BIG DOG
I also have torque steer when taking off hard from the line going STRAIGHT, I'm having so much fun
The R50 pulls harder then ever and seems more willing to go harder longer then every before even after 80,000 miles. The dyno showed it well, before tune, the power band looks like a rollercoaster, after the Tune it just climbs up flat to redline with no dip in power. It just works better.
I have not been to an AutoX with it yet, but was playing around Sat night and know I'll take 1 or 2 sec off my times on a 60 sec setup due to the Tune.
The 2nd tank of gas. I drove the 2nd tank post tune under very normal daily conditions. Going to the office, appts, shopping and running the AC for half the tank. Half the tank at highway speeds some with AC on and off.
Those of you with R50's know that the AC is a power killer and often needs to be turned off to make a pass or get out of the way of faster trucks
Not now. The AC stills takes power out of the motor but not like before. It also idles much better with the AC on.
I also find myself down shifting less when passing or trying to gain speed.
The best part I gained 3 MPG!
I think this winter without the AC or the heat of summer I'll see 5 more MPG. That's right over time, my Tune pays for it's self in gas savings. Your results will vary.
Bottom line, the Tune made everything better for my R50, more power, better throttle response, smooth as silk and more MPG. There's not many things we can do to an R50 for more power like our R53 friends, but a Tune gives you a better R50 that is MORE fun to drive and just does everything better.
Once my motor needs rebuilt I'll do a Head and Cam too.
I'd do it again in a heart beat.
I second everything Dustin just said. Had mine tuned by Jan this past Friday..Much stronger from 2500-5500 then before.
I sold my uni-chip to help pay for my tune and don't regret it one bit!!
Was at VIR yesterday for the Phil Wicks driving class. Much improved power..
I've been wondering, but haven't taken the time to ask jan, whether he can change the idle rpm. I've completely stiffened up my engine stabilizers with some "custom fabricated" parts and I get some insane vibration at idle around 800rpm. I wonder if it is possible to change that to 1k rpm as part of the tune.
we are working on some R50 race engines now and some of that development will work down to the street crowd
no one has made anything for the R50 people and we are ready to branch out to the community to offer some high performance parts for you guys that actually work like it's supposed to. We will be building some "shorty" headers for you too. We will be working on a cam/header solution too.
Oh, and make sure those headers have a cat. Damn CARB-legal Pennsylvania.
all of them come with CARB cats
Oh man... I can't wait to see what you do Jan! I love my '03 R50, but I just want a little more "oomf" out of the engine without going up to an S. I'm definitely looking forward to what's coming!
And HemiHeaded - good choice on the pedal workers (your Pumas)!
Lol... I rock the limited edition Michael Schumacher mid-cut Future Cats for my serious driving, and almost any other Puma when I'm not in need of crazy intense feel and control. Now then, back to the topic at hand...
So are you trying to be like Mike?
I'm sure with a head and or cam that might change.
I found that my K&N was drawing in 140deg air!! So I put the stock air box back with a hi-flo air filter and saw a noticable improvement in power and gas millage. I will be going with a CDA filter and cowl-indution CAI once the battery is relocated to further drop the air intake temps.
BTW I had Mini-Madness due a tune to my R50 with the same results! An ECU Ttune for the R50 is a must!!
Do you have a before and after dyno sheet?
