R56 Surfs up!
Old Jul 22, 2008 | 08:47 AM
jjshoe's Avatar
jjshoe
Surfs up!
Well I'm putting this post out there so you can laugh at me, or relax when you find yourself in my situation.
1) When you put your mini key in your pocket and mentally tell yourself you'll probably forget to take it out before surfing it's a good sign to take it right back out of your pocket
2) The second you get out of the water from surfing and remember that your key is in your pocket take the battery out IMEDIATLY
3) Using a paper towel, q-tip, shirt, or your tongue (to punish yourself for something so silly) clean up as much of the battery leakage/corrosion
4) Set your key in the sunlight, the goal is to dry out the innards of your key COMPLETELY (got the silver ring off but couldn't get it open any further)
5) The next day pick up a new battery and hope you're as lucky as me. Key FOB still works
Old Jul 22, 2008 | 09:23 AM
davo_florida's Avatar
davo_florida
could have been an expensive session. lucky you!
Old Jul 22, 2008 | 09:33 AM
Horatio's Avatar
Horatio
A good way to dry stuff like this out is to put it in a container of uncooked rice rather than just leaving it in the sun. The rice will suck out all the moisture.
Old Jul 22, 2008 | 09:34 AM
bhelton's Avatar
bhelton
Thanks for the tip! Glad it wasn't any worse.
Anybody know how much a new key fob costs with the keyless comfort access?
Old Jul 22, 2008 | 10:07 AM
Robin Casady's Avatar
Robin Casady
I put one through the washing machine and dryer accidentally. Water temp was Cold, and driver was on Delicate. Others have reported doing the same.
I think I heard something like $385 for a replacement fob.
Old Jul 22, 2008 | 10:13 AM
TheBigNewt's Avatar
TheBigNewt
To set the record straight (for me): I have comfort access. Does my battery recharge when I insert it into the slot, or not?
Old Jul 22, 2008 | 10:39 AM
Robin Casady
No, standard non-rechargeable battery. We have to replace it when it gets low.
Old Jul 22, 2008 | 11:34 AM
bhelton's Avatar
bhelton
Yowzas!
Old Jul 22, 2008 | 12:06 PM
MINImizeMe's Avatar
MINImizeMe
I guess it is rechargeable, I remember reading it in manual. It is recommended to be put in the slot at least 2 times a year.
Old Jul 22, 2008 | 12:39 PM
4xAAA's Avatar
4xAAA
I guess that is with the Sport Button off?
Glad it still worked! Whew! Close one.
Old Jul 22, 2008 | 02:42 PM
jjshoe's Avatar
jjshoe
I also have comfort access, and no, the battery is not rechargable. If you take two seconds to pop your battery out you will notice it uses a CR2032.
Old Jul 22, 2008 | 03:27 PM
MINImizeMe's Avatar
MINImizeMe
youre right, i just checked.... I will verify in the manual again
Old Jul 22, 2008 | 03:41 PM
Tüls's Avatar
Tüls
Turbius Maximus
I went into the surf as well about a month ago and forgot my key was in my pocket. Honestly I was less worried about the key not working and just glad it was still in my pocket
Old Jul 22, 2008 | 04:16 PM
TheBigNewt's Avatar
TheBigNewt
The one with Comfort Access isn't rechargable, the regular fob battery is. Which is stupid because you have to put in in the slot every time anyway. Go figure.
Old Jul 22, 2008 | 04:37 PM
4xAAA's Avatar
4xAAA
Not really. I found out by accident that as long as you don't open the doors, you can shut the car off and remove the fob....then start the car without the fob in.
I stopped at Sonic and by habit just punched the fob out of the slot. When I hit the button she started right up. If you open the door you loose the free pass.
Old Jul 22, 2008 | 08:05 PM
MINImizeMe's Avatar
MINImizeMe
I am guessing it may be some sort of packaging issue. regular one can take a bigger rechargeable battery because of less components inside the fob.
IQRaceworks
Jul 15, 2022 05:51 AM
stellaherself
Apr 16, 2016 08:14 PM
CruzinChris
Dec 20, 2004 02:09 PM
Miniphyter808
Apr 2, 2003 12:04 PM
