Suspension Scary Push
Old Jul 21, 2008 | 01:40 AM
silversmoke06's Avatar
silversmoke06
Scary Push
today while cornering I had my car push so bad i went out 3 lanes. not doing anything out of the ordenary Idont understand it im on all stock suspension with Kumho Spt tires. Not bad.
Still the car violetly pushed in the front and the rear continued on going straight. with no change. felt like the front was going completely sideways.
Was a real bust.
Anyone got any ideas why this is happening.
Its kinda freaky to drive its bad enough I dont want to drive it.
Help
Colin
Old Jul 21, 2008 | 02:17 AM
07BPB's Avatar
07BPB
So a lot of oversteer your saying? Umm if thats the case hit the handbrake and release it. Balance the car side ways using the throttle and handbrake but don't pull it on as much as the initial handbrake pull. Depending on entry speed stay in 2nd or 3rd gear with the revs up over 4,500. Have opposite wheel lock and when the back starts coming around steer back into the corner or else the back end will slap back in.
Old Jul 21, 2008 | 06:25 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
You are over-driving the stock suspension. Either slow down a bit or upgrade.
Old Jul 21, 2008 | 06:38 AM
HighLife4136's Avatar
HighLife4136
Check your endlinks too. Mighta broke or come undone.
Old Jul 21, 2008 | 06:47 AM
lhoboy's Avatar
lhoboy
Sounds like something got loose or busted. Even a stock suspension should "tuck in" again after gently letting off the throttle. Check all the steering and swaybar links and frame mounts and do an alignment if no problems are apparent.
Old Jul 21, 2008 | 07:18 AM
blopper's Avatar
blopper
Yep....check rear endlinks. If those are ok SLOW DOWN........
Old Jul 21, 2008 | 07:29 AM
the platform's Avatar
the platform
Was a real bust.
Help
Colin
Time to add suspension mods to counter all the engine performance.The stock suspension is pooh.Sounds more like understeer to me???Time for rear sway bar for starters.
Old Jul 22, 2008 | 01:53 AM
silversmoke06
Again to everyone telling me to slow down.
Nothing out of the ordinary. Meaning not speeding. Duhhh.
Nothing appears to be broken. I quit driving it its parked in my garage. Im driving the vette. Much nicer to not be afraid of your car.
So as for suspension start with reccomendations im up for anything.
Old Jul 22, 2008 | 01:55 AM
silversmoke06
and i think its understeer being i kept turning the wheel to no availll... like someone slipped skateboards under my front end to make it go left.
literaly. It was scary as hell.
I hate it.
Old Jul 22, 2008 | 04:09 AM
snid's Avatar
snid
If nothing is broken, you over-drove the car.
It sounds like attending a BMWCCA Advanced Driver Safety Skills School / Car Control Clinic would be very helpful for you.
If you are in an understeer condition, and you just keep turning the wheel more, you are not going to make anything better.
If you weren't going very fast when this happened, and nothing was broken, there was probably some oil or such on the pavement that lowered the available grip.
Old Jul 22, 2008 | 04:20 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Or gravel. I love sliding through gravel on pavement. Momentary understeer until the gravel ends and then grip like mad causing oversteer.
Old Jul 22, 2008 | 04:24 PM
PGT's Avatar
PGT
maybe the tire pressure is low? sounds like the tire rolled over on you and pushed
Old Jul 22, 2008 | 05:46 PM
RedSkunk's Avatar
RedSkunk
2x. These cars in stock form handle great, not like "pooh" as someone said. If you weren't driving like a jackass, then something might be wrong. In which case it's not time to throw money into the aftermarket..
Old Jul 22, 2008 | 08:26 PM
Longboard Mini's Avatar
Longboard Mini
Man you have some of the strangest things happen to your car.
Don't take this the wrong way but I have over driven the stock suspension and it sure sound like that to me. Like the others have said, if nothings broken, you didn't see gravel or oil, then...... If you truly didn't over drive it and it pushed "three lanes" then you might have it towed to the dealer.
Longboard
Old Jul 23, 2008 | 05:52 PM
silversmoke06
Nahhh Dealer is a no go. Ill figure it out. Im getting new tires. just cause i need them and Ill see if that helps.
Old Jul 23, 2008 | 06:06 PM
Minut's Avatar
Minut
Was it on level ground? I had a bit of scary understeer around a corner that dropped a little at the entry, allowing the front wheels to lose traction before I had completely decelerated.
Old Jul 23, 2008 | 06:21 PM
silversmoke06
i was heading slightly up hill it was really more of a lane and a half.
Old Jul 24, 2008 | 10:21 AM
lhoboy's Avatar
lhoboy
On the uphill sweeper, were you still under substantial power? If so, it is the suspension (and/or tires) needing an upgrade. If under neutral or slightly lifted throttle, the front end should have come back in again. If this was the case, something is out of alignment (either broken or out of adjustment).
If you were doing over 100mph, then you got air under the front end and you need a better air dam.
Old Jul 24, 2008 | 08:00 PM
Some Guy's Avatar
Some Guy
QFT. Or at least go to an autocross or two so you can learn the limits of your car in a safe environment. I have only attended 4 autocrosses and already I am a much safer driver on the road because I am not constantly pushing my car like I used to. I learned that I was actually getting a lot closer to my cars corning limit than I really thought I was.
Old Jul 24, 2008 | 08:02 PM
PGT's Avatar
PGT
wow.....I was the opposite. I was always afraid to push it on the street for fear of it being uncontrollable. Quite the opposite....grip levels are MUCH higher than I thought and the car is VERY progressive at the limit - no surprises. When I overdrive it however...the front end will push hard and there's no correcting it by staying in the power.
Old Jul 24, 2008 | 10:35 PM
Some Guy's Avatar
Some Guy
Probably the difference between the all seasons I run and the summers that you probably run.
Old Jul 24, 2008 | 10:51 PM
silversmoke06
Nah not over 100 on the streets.
I was doing a regular yielded Right onto a surface street albiet a large street. i was applying power. but not substantial. and like i think i mensioned im not sure im running kumho spt. Im going to hankook rs2s soon.
Filmy
15
Jun 6, 2023 06:27 AM
Lex2008
How to
47
Jun 15, 2022 06:18 AM
Filmy
Jun 28, 2016 08:58 AM
Rainforest_Elf
Sep 15, 2015 12:11 PM
Sep 4, 2015 03:56 PM
