R55 John Cooper Works
John Cooper Works
im considering getting a mini clumbman. im debating on the s or the JCW.
what im trying to determine is if the ride height is lowered or if the suspension is changed from the S to the JCW.
it appears that the JCW package only upgrades the motor and exhaust.
what am i missing?
thanks.
p.s. i also noticed that the gear pattern with the 6 speed is red on the JCW.
what am i missing?
thanks.
what am i missing?
thanks.
what am i missing?
thanks.
It has the same suspension as the S. The biggest differences are the engine, transmission/clutch, Diff, and brakes. No need to worry about ride height. The clutch will be slightly stiffer but not that much.
PS There are quite a few threads on the JCW check them out they may help you make a decision.
Go to this link to read about driving a new JCW.
He talks about the heavier clutch.
https://www.northamericanmotoring.co...d.php?t=147867
i just read it thanks.
is the JCW aero kit different then the standard aero kit?
also, how is the clutch on the S, is it heavy? has anyone been in heavy traffic with it?
excellent.
thanks.
thanks.
There are two aero kits for JCW. One is the factory install version and the other is the "dealer" install that can have carbon fiber components. Look at the build they do not look the same. I liked the carbon fiber diffuser and opted for the dealer option. In either case they will be on when you pick it up. It's best to do the builds at MINIUSA and look at which one you like best.
I have driven the new car on two different occasions,I drove it pretty hard.The clutch is basically the same as my JCW and the transmision is smooth.This is a Mini not a truck..You won't find it do be a problem,just enjoy the car..
Dec 23, 2015 10:36 AM
