Drivetrain Another plug question
Old Jul 7, 2008 | 06:07 AM
mcsmike's Avatar
mcsmike
I know its recommended to change to a colder heat range when doing the stage 1 upgrades. Ive been searching and have found that most people switch to ngk br7eix, but I was wondering if br8eix were fine to run? A store has those locally so it would be easy to pick them up. Not sure if outside temperature has any effect considering the heat the combustion creates anyways, but I live in southwest florida where 90+ degree weather is normal not to mention 80% humidity.
So my question is, are br8eix safe to run with a 15% pulley intake and oneball?
Old Jul 7, 2008 | 07:33 AM
ScottinBend's Avatar
ScottinBend
Definitely go for the colder plugs as ambient air temp is a concern. Many would also suggest you get a set of the JCW OEM NGK plugs. Fairly inexpensive and available online at NGK.com
Old Jul 7, 2008 | 08:13 AM
MSFITOY's Avatar
MSFITOY
Unless you are running extreme mods such as nitrous and or twin charged, br8eix (two steps colder) would be unecessary. Br7eix is one step colder and appropriate for yours (and my) mods...
Old Jul 7, 2008 | 12:42 PM
mcsmike's Avatar
mcsmike
Thanks for the replies, I figured two steps might be too extreme. Guess I will just have to order them online.
Old Jul 7, 2008 | 01:31 PM
MSFITOY's Avatar
MSFITOY
Just received a set from Ecrater for 25 shipped...
Old Jul 7, 2008 | 01:36 PM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
What are people running with 17% and rmw head/cam/ 440's?
Old Jul 7, 2008 | 02:27 PM
El_Griton's Avatar
El_Griton
The oem jcw plugs should be fine with those jack. that head is going to run cooler anyways, its flowin so much.
Old Jul 7, 2008 | 02:37 PM
carbonized's Avatar
carbonized
That,s basically what Sid has in MSFITOY.
I've been running the 8 for a while without problem but it's probably overkill
Old Jul 7, 2008 | 03:43 PM
batrugger's Avatar
batrugger
Jan told me to use the NGK BKR8E1X gapped at .028 and we have those mods
Old Jul 7, 2008 | 04:08 PM
El_Griton's Avatar
El_Griton
there you go.
Old Jul 8, 2008 | 05:25 AM
Tstroh's Avatar
Tstroh
gap?
I dont know a ton about spark plugs, is the gap something i should be worried about, say i go to an auto parts store for some NKG's and say i need some for an 02 MCS one step colder, will they just know what i am looking for, and is there something i have to do to have it gapped right?
Old Jul 8, 2008 | 05:29 AM
MSFITOY's Avatar
MSFITOY
Don't have 440's or a RMW tune...yet...
Old Jul 8, 2008 | 06:47 AM
jtack's Avatar
jtack
I am no spark plug expert either but I can tell you that I had the NGK BKR7EIX-11 which are pre gapped at .045. I was having pinging issues and notice that Jan was saying to gap at .028. I gapped at .035 and it took care of the pinging issues but it doesnt seem as snappy for some reason.
Old Jul 8, 2008 | 07:54 AM
Bahamabart's Avatar
Bahamabart
I am swapping out my plugs and Gnaster suggested the ones being discussed and referenced a .045 gap.
Old Jul 11, 2008 | 12:55 PM
littlehandegan
I cant find that part number anywhere? Is that correct? Or should it be BKR8EIX????
Old Jul 11, 2008 | 01:03 PM
jtack's Avatar
jtack
BKR8EIX NGK Iridium is correct.
maniacalmorgan
Jan 1, 2020 11:20 AM
W0TM8
Dec 19, 2019 07:50 AM
robbiedowns22
Aug 25, 2015 12:20 PM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
Getrieben
Aug 15, 2015 09:09 PM
