R55 Gear shaped warning signal?
Old Jul 4, 2008 | 12:46 PM
harold47's Avatar
harold47
Hi:
After turning my engine off there appeared a warning signal, looked like it was the shape of a gear, can't find anything about it in the manual.
anyone know about this?
Happy 4th!
Old Jul 4, 2008 | 01:02 PM
Chilao's Avatar
Chilao
maybe the tire pressure lamp?
Old Jul 4, 2008 | 01:08 PM
harold47's Avatar
harold47
no, not the tire pressure signal, but thanks.
Going to start it again and see if it comes on, I will take a picture of it.
Old Jul 4, 2008 | 01:09 PM
DragonWagon's Avatar
DragonWagon
I see two gear shaped warnings in a PDF manual.
1) Gear with thermometer in it - Transmission Overheating
2) Gear with exclamation point - Transmission in limp home mode.
If the warning was Red, it's worse than if it was yellow.
You may need to contact the dealer. Good luck.
Now, it's time to put in my time on the running trail.
Old Jul 4, 2008 | 01:50 PM
harold47's Avatar
harold47
Here are photos
Just went to start the car, and this is the pictures of the 2 signals that came on. The car was in park, but maybe I had a senior moment and it wasn't?
Anybody have any experience or info on this?
What is limp home mode?
Attached Thumbnails Gear shaped warning signal?-100_1256.jpg   Gear shaped warning signal?-100_1258.jpg
Old Jul 4, 2008 | 01:59 PM
Corey986's Avatar
Corey986
Common issue on the automatic. If you had nav it would say you didn't put the car in park before you shut it off. I had this as have countless others and you need to have the dealer check it. On mine they had to replace a sensor or interlock or something like it. My was about a week old before this 1st happened.
Old Jul 4, 2008 | 02:08 PM
harold47's Avatar
harold47
Thanks!
Not Red or Yellow- Orange???
Anyway, turn on the car drove a few feet and turned it off, warning didn't come back on, this time- dealer is 45 min drive, think I need to bring it in? Anything dangerous?
If it is best to bring it in, I will, just don't want the hassel if not.
Thanks again!!!!
Found this on the 2007 PDF, don't see a clubman PDF or 2008:
[FONT=MINITypeRegular-Regular][SIZE=1]
Lights up in red:
[/SIZE][/FONT][FONT=BMWExtra][SIZE=1]
[/SIZE][/FONT][FONT=MINITypeRegular-Regular][SIZE=1]Transmission limp-home program
active with restricted range
of gears, possibly with reduced
acceleration
You can continue your journey, but
moderate your speed and exercise
due caution. Have the system
checked without delay.
[/SIZE][/FONT][FONT=MINITypeRegular-Regular][SIZE=1]Gears can be engaged without
depressing the brake
Always depress the brake to engage a
gear.
[/SIZE][/FONT][FONT=MINITypeRegular-Regular][SIZE=1]Automatic selector lever locked Overriding the selector lever lock,
page [/SIZE][/FONT][FONT=MINITypeRegular-Regular][SIZE=1]39
Lights up in yellow: Have the system checked as soon as
possible.
[/SIZE][/FONT][FONT=MINITypeRegular-Regular][SIZE=1]Automatic selector lever locked:
Selector lever locked in position P
with engine running and brake
depressed or
[/SIZE][/FONT][FONT=MINITypeRegular-Regular][SIZE=1]brake signal malfunctioning: gear
can be engaged without depressing
the brake
To engage a gear while the vehicle is
at a standstill, always depress the
brake. Before leaving the vehicle,
move the selector lever to position P
and switch off the engine.
[/SIZE][/FONT]
Old Jul 4, 2008 | 03:09 PM
DragonWagon
Harold, your data from the pdf file is the same as mine. Your error looks yellow, not red.
I agree with Corey's assessment.
Old Jul 4, 2008 | 03:27 PM
harold47's Avatar
harold47
Thanks!
Old Jul 4, 2008 | 04:54 PM
Robsreef's Avatar
Robsreef
I had this happen on our new MCS Automatic Clubman with 2k miles on it. It is the gear selector sensor. Our light came on about 4 weeks ago. My dealer told me just to bring it in at my convenience and that their demo Clubman was doing the same thing. Don't be surprised if you see other dummy lights come on. After one week of driving with that light on, our brake, DSC, and tire pressure light was staying on too. Again, the dealer said that was what their demo and one other customer's automatic Clubman was doing. I drove it for another week and then every time my gas tank was only half empty, the gas light was going on and off when I would take any corners. The dealership finally got my part in last week and they fixed it. I drove it for 3 days with no issues. Now the light is back on but it has only gone on two or three times. It has not come back on in two days but I'm still going to get it back into the dealer. UHGGGGGG
Old Jul 4, 2008 | 06:08 PM
tim781996's Avatar
tim781996
From the picture, it looks like it's telling you the Sun is going to explode unless you put the car in P.
Old Jul 4, 2008 | 07:04 PM
Otra's Avatar
Otra
My Clubman is my third automatic but first automatic of the 2nd Generation...thus far I have never seen this icon - and hope I never do. Corey posted that it was common - well perhaps for the 2nd Gen? It surely shouldn't be.
Best wishes for a quick and timely fix. I have no patience with stuff like this going bad on a brand new car.
Old Jul 4, 2008 | 07:31 PM
DragonWagon
Tim gets a cookie for making me laugh out loud.
I'm usually too damn bad to laugh out loud!
HAROLD, check with your Dealer on Monday, no matter what.
Old Jul 5, 2008 | 08:23 AM
harold47's Avatar
harold47
thanks.
Send pics to my slaesman- he is asking the service mag this am.
Old Jul 5, 2008 | 06:47 PM
harold47's Avatar
harold47
drove it today- no warning light. maybe I did turn it off while not in park?
Gonna see what happens- or not happens- in the next few days.
Old Jul 5, 2008 | 08:39 PM
DragonWagon
Harold, as other smart peeps above mentioned, the problem may have been 'premature ejection.'
If driving an Automatic, you're more likely to hit the Start/Stop button early.
Live and learn.
Old Jul 6, 2008 | 04:03 PM
harold47's Avatar
harold47
My Tire Pressure monitoring system light cam on today.UGGHHHHH is right!
Going to call my dealer tmw morning.
What was the part they had to change in your car?
Ayone else?
Thanks!
Old Jul 6, 2008 | 04:20 PM
harold47's Avatar
harold47
Hi:
Yesterday my transmission gear indicator lamp warning, today my tire pressure monitoring system shows right front tire low.
I live quite some distance from the dealership. Would you mind plese telling me exactly what part(s) they had to change in yours so that I can have them order for me prior to my going up there and save a trip and a 1/2 day?
Thanks!!
Old Jul 6, 2008 | 04:49 PM
LarryParker's Avatar
LarryParker
ClubRed
Just wondering, did you check tire pressure? Then did you reset Light?
Just wondering.
Larry
Old Jul 6, 2008 | 05:00 PM
Robsreef's Avatar
Robsreef
Ayone else?
Thanks!
They replaced the tire pressure monitor and the Automatic gear selector sensor because they were both bad sensors. My gear selector light has been off for a couple days but just came back on this morning. I drove the car a couple more times through out the day and it never came back on. I have no idea what the heck is wrong with it. I will be taking it back to the dealership soon though. I'm just glad that the car still runs fine and I can drive it.
Old Jul 6, 2008 | 05:54 PM
harold47's Avatar
harold47
Just wondering.
Larry
yes, 30psi on all 4.
Old Jul 9, 2008 | 07:56 PM
harold47's Avatar
harold47
light came on again.
brining it in for service monday- said they could not order the part until i bring it in and they check the codes?
Old Jul 10, 2008 | 04:34 AM
Otra's Avatar
Otra
Old Jul 10, 2008 | 05:42 PM
LadyGodiva's Avatar
LadyGodiva
Harold, just found this: https://www.northamericanmotoring.co...d.php?t=142643
Old Jul 10, 2008 | 06:30 PM
harold47's Avatar
harold47
thanks!
