NEED HELP WITH TIRE SIZE AND CROSS SUSPENSION
Old Jul 3, 2008 | 12:12 PM
paco3's Avatar
paco3
I looking to get new tires to replace my Run Flats, the problem i have is the tire size, I would like to get 215/40R/18 instead of the 205/40R/18. I have lowered my mini 1.5in with the Cross susp. the people of Tire Rack told me that they will not warranty that the 215/40/18 will not rub. Is anyone using 215/40/18 with Cross Susp...?
Old Jul 3, 2008 | 12:21 PM
COR BLMY's Avatar
COR BLMY
If stock wheels ... or lots of positive offset .
5mm spacers will fix any issues you may have.
Just measure the front wheel distance from area where the tire meets the rim ..to the coilovers...that is where it will touch
Old Jul 3, 2008 | 12:24 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
No problem at all - you can run those. Do you know the offset of your 18s? It is usually stamped in the inner part of the wheel.
Randy
Old Jul 3, 2008 | 03:29 PM
paco3's Avatar
paco3
The JCW are 52mm offset.......
Old Jul 3, 2008 | 03:35 PM
works8's Avatar
works8
I run 214/40R18 PZero Nero on a 18x7 ET52, no probs.
Old Jul 3, 2008 | 04:14 PM
PGT's Avatar
PGT
not on Cross according to your sig.
215/40/18 is a bit tall. 225/35/18 is a better match but not on the stock wheels though
Old Jul 3, 2008 | 04:25 PM
paco3's Avatar
paco3
The difference between the 205 Vs 215 is 3.22in sidewall for the 205 and 3.38in for the 215 with a diameter diff of 1.3%
kazyn
Oct 25, 2019 02:34 PM
TJANK
Aug 24, 2015 06:11 PM
col127
Aug 21, 2015 02:11 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
