R50/53 Turning radius is not very good...
Old Jun 24, 2008 | 09:49 PM
bmwg84's Avatar
bmwg84
I used to be able to make a U-Turn on my residential street with all of my past BMWs and Mercedes, but this Mini cannot make the turn - even 'though it is MUCH smaller than those other cars. Is there something wrong with my car??
Old Jun 24, 2008 | 09:54 PM
Xymox's Avatar
Xymox
Nope. That's also a complaint of the Car and Driver staff too.
Old Jun 24, 2008 | 09:56 PM
bmwg84's Avatar
bmwg84
Ok, cool. you just saved me a trip to the mechanic. I was hearing a whining sound at idle today and thought that it may be the power steering. Apparently that is normal too
Old Jun 24, 2008 | 10:13 PM
silversmoke06's Avatar
silversmoke06
Yep its the powersteering Beats the hell out of ford powersteering its very loud when not serviced.
The turn circle is not that badd.... I think its fine.
Old Jun 25, 2008 | 02:55 AM
navycav3's Avatar
navycav3
im not sure which you are talking about, but the mini power steering is loud, service or not!
Old Jun 25, 2008 | 04:09 AM
k_h_d's Avatar
k_h_d
Weird... So far I have only owned one car that could turn tighter than the Mini and it was a jeep. That thing had the sharpest turn of any car I have seen.
Old Jun 25, 2008 | 04:18 AM
Minian's Avatar
Minian
Same here, I owned a 318, 320, 525, and a 635 and none of them turns as sharp as my Mini that I can remember.
Old Jun 25, 2008 | 04:32 AM
MINIFVR's Avatar
MINIFVR
Test drive a Volvo S60 and then see how you feel about your MINI's radius...you won't complain then!
Old Jun 25, 2008 | 04:33 AM
eager2own's Avatar
eager2own
Actually, my 325 (E46) turns almost exactly like the R52
Old Jun 25, 2008 | 07:09 AM
redR56's Avatar
redR56
In theory rear-wheel-drive cars can have rather smaller turning circles than front-wheel-drive cars.
If you pine for a rear-wheel-drive MINI, you really want a BMW 2002 (turning circle 9.60m compared to R56's 10.7m).
Old Jun 25, 2008 | 07:12 AM
bmwg84's Avatar
bmwg84
What is the science behind the RWD making tighter circles? I don't understand it
Old Jun 25, 2008 | 07:16 AM
Minian's Avatar
Minian
It's called a doughnut or drifting.
Old Jun 25, 2008 | 07:31 AM
hunter99's Avatar
hunter99
The drivetrain is not connected to the drive wheels on a rearwheel drive car.
Old Jun 25, 2008 | 07:47 AM
redR56's Avatar
redR56
It is connected, you probably meant. The drive mechanisms connected to the steering wheels in front-wheel-drive cars tend to limit lock-to-lock angles.
Old Jun 25, 2008 | 07:53 AM
Gromit801's Avatar
Gromit801
You must have one very, very narrow street. I have to make two u-turns a day on the side street next to where I work. No problems.
Old Jun 25, 2008 | 07:55 AM
Pretzel Logic's Avatar
Pretzel Logic
LOL I agree. My S60 R with 18" rims has the turning radius of a school bus. It makes even pulling into regular supermarket parking spots into a 3 point turn affair. Absurd. Mini is MUCH better.
Old Jun 25, 2008 | 08:02 AM
Edge's Avatar
Edge
AdMINIstrator
Bear in mind also, that if this MINI has (or has previously had) the 18" JCW wheels, then there is a requirement (at least "officially") to install a "steering angle stop", which slightly reduces the maximum turning angle and therefore increases the turning radius. So, if that applies to your MINI, it's the likely reason that you're disappointed.
In my case, it was the only downside to moving up to the JCW wheels when I got them.
Old Jun 25, 2008 | 08:23 AM
lawmann's Avatar
lawmann
Coordinator :: Middle Georgia MINIs
Old Jun 25, 2008 | 08:25 AM
lawmann's Avatar
lawmann
Turning Radius
I have no issues. The only car I owned that turned tighter was a 1971 MG Midget. I think my '06 R53 turns pretty dang good!
lordgrinz's Avatar
lordgrinz
Originally Posted by lawmann
LMAO
Old Jun 25, 2008 | 10:22 AM
DixonL2's Avatar
DixonL2
ON an FWD car, the drive axles have to connect to the front wheels, limiting their ability to turn since the axle must always be in the middle. On a RWD car, the limiting factor is the amount of space around the front wheels and the steering geometry, so (given the proper geometry) the front wheels on a RWD car can almost turn at 90 degrees.
That said, I'm pretty satisfied with the turning circle, comparable to the good FWD cars I've owned, better than most.
Old Jun 25, 2008 | 10:23 AM
rallymaniac's Avatar
rallymaniac
Well MINI does turn sharp (as to small move of the steering wheel yields big turn) but this is due to the quick steering rack.
I do have to agree that the turning radius sucks. This was one of the first things that I discovered after getting the car. I alway's reverse into my garage and I'm able make less of a turn to prepare for reverse compared to my last car. In other words, the wheels are hitting the turn-stops much quicker than in other cars and you can't make the turn deep enough.
Old Jun 25, 2008 | 10:41 AM
Speedwing's Avatar
Speedwing
Tightest turns are done in reverse! http://www.youtube.com/watch?v=wQPVrkaX7sQ
Old Jun 25, 2008 | 01:29 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
fixed it for you.
Old Jun 25, 2008 | 02:37 PM
Dan00Hawk's Avatar
Dan00Hawk
I've found that handbrake turns in the snow make for small radius u-turns in the Mini (and other FWD cars as well).
A friend's Evo had the worst turning radius of any car I've ever driven...
Mini seems no worse and no better than most other vehicles to me.
