Media blasted finish on wheels
Old Jun 23, 2008 | 03:09 PM
k_h_d's Avatar
k_h_d
Does anybody have a point in the right direction or any information on possible media blasted finishes on wheels? I stripped the paint off of a wheel and the alloy actually may look pretty good if it can be blasted to a desired finish and then clearcoated I assume.
Is this possible and has anybody seen any results from this?
Old Jun 23, 2008 | 03:24 PM
miniconcarne's Avatar
miniconcarne
So like a satin look? Depending on the blasters talent, may look pretty good. Do it and have a clear powder coat done, interesting.
Old Jun 23, 2008 | 03:28 PM
k_h_d's Avatar
k_h_d
Satin is one of the thoughts. From my very limited research depending on the media type and size even smoother than satin may be possible.
Old Jun 23, 2008 | 03:33 PM
daemon2's Avatar
daemon2
Try sanding the alloy by hand with automotive paper, then clear coat after you get the disired finish. Aluminum looks great this way, I helped an uncle do his MX-6 years ago. The wheels were very nice after removing the paint and sanding.
Old Jun 23, 2008 | 04:10 PM
k_h_d's Avatar
k_h_d
That is a thought. I am sure it takes a good bit of sanding however. Do you recall how fine of sandpaper you ended up going to and how smooth it looked when finished?
Old Jun 30, 2008 | 12:37 PM
daemon2's Avatar
daemon2
Sorry it took so long to get back, we worked down to an 800 wet paper. The finish was beautiful, a real eye catcher. I will see if I can dig up some old photos
Alkaidovich
Jan 30, 2021 01:35 AM
ebowling
90
Aug 4, 2019 09:15 AM
Tylerlanger1
Aug 21, 2015 03:03 PM
Mini'mon
Aug 16, 2015 04:15 PM
Dashdog
Aug 10, 2015 06:17 AM
