Suspension 21mm strut socket
Old Jun 23, 2008 | 06:04 AM
bugkiller's Avatar
bugkiller
21mm strut socket
not sure where this thread needs to be located but i figured this is a good start. i'm looking to rent/borrow a 21 mm strut socket to change my springs. obviously i could purchase this item but i'd much rather go the cheaper route if possible. if anyone has this tool for me to rent/borrow please let me know. i know i can get remove the nut but my concern is retorquing the entire assembly to the correct setting - any assistance would be much appreciated!
Old Jun 23, 2008 | 05:25 PM
WLSH BST's Avatar
WLSH BST
I bought a regular 21mm deep socket and dremelled a window in the socket so that it looked just like the real thing. $5 instead of $60. I believe someone on the octaneguy brake writeup recomended this approach - it worked for me.
Old Jun 23, 2008 | 05:28 PM
BlimeyCabrio's Avatar
BlimeyCabrio
I was just trying to figure out how I was gonna get one of these for my forthcoming strut install.... WOOHOOO!.... great idea... I have the tools to cut down a socket in about 2 minutes... THANKS!
Old Jun 24, 2008 | 06:18 AM
bugkiller's Avatar
bugkiller
so will it withstand the tremendous amount of torque to loosen and tighten this nut? i thought about doing this too but i was afraid of weakening the socket iteself.
Old Jun 24, 2008 | 09:57 AM
BlimeyCabrio
I'll be able to tell you in a week.
But I suspect it will be FINE. I may use an impact wrench to loosen mine, anyway... tightening torque really isn't that big a deal (it's not likely to break the socket)
But socket steel is pretty strong stuff... a little bit can hold a lot of torque...
Old Jun 24, 2008 | 10:08 AM
Eric_Rowland's Avatar
Eric_Rowland
Old Jun 24, 2008 | 10:11 AM
BlimeyCabrio
Great pic, Eric... that's what I'm gonna make...
Old Jun 24, 2008 | 10:13 AM
mjgmcs1's Avatar
mjgmcs1
Look here:
https://www.northamericanmotoring.co...rut+nut+socket
Old Jun 24, 2008 | 01:33 PM
UKSUV's Avatar
UKSUV
I just used a spark plug socket so I could insert a hex head thru the top and then use a wrench on the top of the socket.....works great.....
Old Jun 26, 2008 | 04:38 PM
WLSH BST's Avatar
WLSH BST
The picture Eric posted, thats what I cut a regular 21mm deep socket to look like. It was plenty strong enough and dirt cheap.
YaTuSabe
Aug 23, 2018 11:41 AM
OutMotoring
Mar 3, 2017 06:29 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
Suspension Products
Oct 1, 2015 11:53 AM
EVMini
Sep 28, 2015 10:20 AM
