R50/53 Just got my first MINI I have questions
Tires and wheels probably have the most effect. 16"s ride better than 17"s, real tires ride better than runflats. Different tire brand/models run differently. What wheels and tires do you have.
The MINI ride is just kind of harsh, no matter what you do to it.
as others have said, the rims and tires will make a huge difference. the mini however is not the best riding car on earth, lets be real about this. I have a R53 and my wife always comments that it is so "stiff and bouncy" when hitting bumps, but i hardly notice it. On the flip side when i drive a car other than a mini i feel like its kind of "boaty" and unstable. short story: loose the runflats, go with 16" rims and give it a little while.
The smaller the rim, the more tire sidewall you will have. The amount of rubber between the road and the actual rim determines the harshness of the ride. On the flip side, less rubber between gives you better handling since you lessen the amount of tire roll. A 15 inch rim will give you an additional inch beteen the pavement and rim if you replace a 17. Tire composition makes a huge differance too. Run flats are very heavy since they have a thick "self repairing" sealant on the inside of the tire. Heavy tires transmit more bounce than a lighter weight non-run flat.
Before jumping into a 15 inch rim, install a set of higher quality non-run flat tires. Just keep in mind you don't have a spare tire, bit that anyone actually changes them on the side of the road anymore...
If you have 17's I recommend Goodyear Eagle F1 GS-D3 215/45ZR17. They make the ride a bit smoother & still stick like glue on the twisties.
Of course I have always driven small cars & prefer the feel of them so I am not an expert on a super smooth ride
I just went through this about 2 months ago, this board as well as friends in the MINI community were united in saying the same thing, ditch the run flats. I did and could not be happier, The car went from a nightmare that i was going to sell after three weeks to a much smoother ridiing car!!!! seriously it is night and day. The funny thing is that I have four nearly new runflats and ran them on ebay three times and can't sell them. No one wants the darn things. For the record I had dunlop 9000s RSSTs tyres and went to normal Dunlop 9000s. Do it, you won't be dissapppointed, I was avoiding even the most tiny road imperfections before.
Peter
Peter
I don't think there is a difference. The only thing I can say is that the pressure will not change. Now does that mean a softer ride? I wouldn't think so.
. Seriously though I just carry a compressor and a can of slime.
i have to wait till run flat wear out...
why did mini even make the S's have run flats? was there even a real point?
someone please enlighten me.
Runflats are seen as safer, and thus desirable by people who've never driven on them.
Also the lack of a spare on the S means they've got to do something and they don't seem comfortable selling the "MINI Mobility System" (ie a compressor and a can of slime) in the US. Don't forget the S can't have a spare because the battery is where the spare would be, because the supercharger/intercooler is where the battery would be.
The runflats actually work by having very stiff sidewalls. They're stiff enough you can run just on the sidewall, without pressure, at least for 50 miles. The stiff sidewall is what gives them their crappy ride, its just stiffer than a normal tire. Its also what makes them weigh more.
