R55 triangle with an exclamation in it.
Tonight I noticed a little triangle with an exclamation point in it in the tach display area. It is right in between the odometer and the trip meter. The manual just states " the vehicle may start the next time without the brake depressed" . I don't get it. I will say though I am down to two red candy corns on the fuel gauge. I wonder if it is another way to let me know i need fuel?
If that little exclamation point in a triangle is near the odometer, I think it means that your Mini is hungry. In my 07 MCS when there are 2 red ticks left on the fuel gauge it puts a silhouette of a gas pump on the tachometer display screen and bongs at me. After that, there is a little exclamation point inside of a triangle near the odometer. Go feed the poor thing, it's probably starving!
That does sound like it just needs gas. Mine will normally warn me a couple of times that I'm low on gas, then the indicator will go away. But if ignored and I get too low, it will stay on as if to say "Go get some gas dummy!"
VanisleRyan
26
Sep 15, 2015 06:19 AM
silence2-38554
Aug 29, 2015 08:10 AM
Aug 12, 2015 01:24 PM
