Drivetrain Intake Cleaners
Old Jun 12, 2008 | 08:20 PM
Striped Toad's Avatar
Striped Toad
Intake Cleaners
Are the cleaners the same for foam and paper intakes?
Old Jun 12, 2008 | 08:28 PM
SimpsonGI's Avatar
SimpsonGI
Coordinator :: Emerald MINI Car Club
The cleaner (from ALTA) I have is specific to foam filters.
Old Jun 12, 2008 | 08:30 PM
Nitrominis's Avatar
Nitrominis
I am not sure about the question?
You can use Simple Green on K&N, Uni, and foam filters. There is no cleaner for a paper air filter that I have ever seen.
Old Jun 12, 2008 | 08:36 PM
Striped Toad
Sorry, i mean foam and the oil, coton/mesh filters like k&n
Old Jun 12, 2008 | 09:13 PM
Nitrominis's Avatar
Nitrominis
OK then Simple Green is cheaper works great for cleaning and will not hurt the K&N filter. I would stick with K&N oil when finished cleaning it. And if you want to be different Ford Motor Sport carries there house brand(they get it from K&N) oil for there K & N filters and it is blue.
Old Jun 12, 2008 | 09:17 PM
Nitrominis's Avatar
Nitrominis
I should ad it is ok for cleaning any foam type filter also.
Old Jun 13, 2008 | 12:34 AM
Luys's Avatar
Luys
The foam has different cleaner from the cotton
Old Jun 14, 2008 | 01:10 PM
Striped Toad
Hmm... So im confused, Simple Green? Regular Simple Green? Will the Ford Oil (blue) show up with the (red) ALTA?
Old Jun 14, 2008 | 02:35 PM
Nitrominis's Avatar
Nitrominis
Ya sorry I did seem to confuse things. Simple Green will work to clean any foam or K&N filter without harm. If you have a UNI or K&N filter it would be better after cleaning that you stay with there oil to re-oil the filter. If you have a K&N filter there is 2 oil colors availible to re-oil the filter. the traditional K&N red and the one that they sell to FORD Motorsport which is blue. It is kind of neat to be a bit different with the blue because it is not common knowledge that it is K&N oil. And no it will not show the red if you cleaned the filter properly.
Old Jun 14, 2008 | 03:23 PM
ED955S's Avatar
ED955S
I run out of my K&N cleaner but still have lots of the re-oil left. Can you please confirm if Simple Green regular or the Simple Green Pro-series Max?
Old Jun 14, 2008 | 03:46 PM
R56 Ed's Avatar
R56 Ed
After you're done cleaning...
Be sure not to over-oil the filter! Too much filter oil can cause problems with the air mass sensor which is downstream from the filter, and might cost you big bucks. Wish I didn't know from personal experience! Problem was on a different vehicle, but the principle should be the same.
Old Jun 14, 2008 | 03:57 PM
Goodwood's Avatar
Goodwood
Simple Green or Pro Series Simple Green, it doesn't matter... use the cheaper one.
Old Jun 14, 2008 | 06:26 PM
Striped Toad
The foam filter is red.. It will conceal the red and make it blue?
Old Jun 14, 2008 | 07:13 PM
ED955S's Avatar
ED955S
Well, I used the Simple Green Cleaner today on my Mini & Honda. It's not as good as K&N but it works. I sprayed and soaked for 10 mins and rinsed with water. I did this twice. It has that nice fresh smell too.
Old Jun 14, 2008 | 07:38 PM
Nitrominis's Avatar
Nitrominis
Ahh not sure about. But hey if you use the blue oil on your red filter it might turn GREEN the color of your MINI.
The original simple green is all I have ever used.
hypnohealer when to oil starts run off you got to much oil.
I have done it myself.
After you oil you filter and have covered all the pleats or surface let it soak for 10-15 minutes. The take a clean rag and dap the excess off.
ed955s It is a plot so you by the set of cleaner and oil. they know that the cleaner goes 3 times as fast.
I love the smell of clean parts. No kidding I use my dishwasher sometime to wash parts. think about it? If you spray them with simple green first rinse them and throw them in the dishwasher. They will get hot washed and heat air dried. What could be easier?
I have beed through 3 wives however. They never understood
Old Jun 14, 2008 | 07:54 PM
billzcat1's Avatar
billzcat1
Originally Posted by hypnohealer
Too much filter oil can cause problems with the air mass sensor which is downstream from the filter.
And what air mass sensor might that be?
Old Jun 20, 2008 | 02:16 PM
Striped Toad
Used Simple Green on it the other day and it worked great! Only had to spray it once and let it soak for about 10 min, then followed up with the K&N oil. Thanks for the suggestions!
rtk90
Aug 29, 2019 09:08 AM
67morris
May 7, 2016 11:52 AM
Sep 11, 2015 11:09 AM
kjd186
Sep 9, 2015 10:02 AM
