R50/53 Questions / Possible problems with my MINI
Old Jun 12, 2008 | 04:34 PM
cmaples's Avatar
cmaples
I just bought a used 2002 cooper S and have found a great deal of the information I needed on this site. I still have some questions I haven't been able to find answers to:
Question #1. My car came with ASC. Is there anyway to upgrade to DSC? Is it just software or do you need new hardware as well?
Question #2. Does the rear sun roof open on this model year? I'm almost positive I've seen pics of other peoples minis and the rear sun roof is popped up. Is mine broken or is that only on later models.
Question #3. My owners manual says the following about the '02 . . . .
"Convenience feature via door lock: You can also operate the power windows and the sliding/tilt sunroof via the door lock.
>To open: with the door closed, turn the key to the "Unlock" position and hold it
>To close: with the door closed, turn the key to the "Lock" position and hold it
This doesn't work. I can't open or close them from outside the car with the key. Any ideas?
Question #4. The windows have an auto down feature. Briefly press the switch and the windows go all the way down. The manual says they have an auto up feature as well but it doesn't work . . . .
To close:
Press the switch upwards. The window closes until you release the switch
or when the engine is running:
Briefly press the switch upwards. The window closes automatically. Pressing the switch again stops the operation.
Any help or suggestions would be greatly appreciated. I tried to not be a total noob and used the search feature but was unable to find the info I was looking for. Maybe I was searching for the wrong things. Thanks in advance.
Very Respectfully,
Clint
Old Jun 12, 2008 | 04:43 PM
DooLocsta's Avatar
DooLocsta
If it makes you feel any better I just recently got an 05 and the auto up thing does not work for me either.
Old Jun 12, 2008 | 04:50 PM
astra's Avatar
astra
1. NO
2. No .. not until 2007 does the rear sunroof window open..
3.when you lock the car with the key in the door, if you hold it in the lock position, the windows and sunroof will close..
on the other direction, when you unlock the car with the fob.. the first click opens the drivers door.. press and hold.. the rest of the car unlocks and the windows and sunroof will open for as long as you hold the button..
4.Unless you have a car that has the aftermarket card in it.. auto up will not work.. there are no sensors in the car for it.you have to hold the switch for them to close..
good luck
Old Jun 12, 2008 | 05:53 PM
Xymox's Avatar
Xymox
Correct. However, I found out the other day that pressing and holding the "unlock" button on the keyfob opens both windows, sunroof, as well as unlocks the car. Ok, I still wish it had auto-up.
Old Jun 12, 2008 | 05:57 PM
MLPearson79's Avatar
MLPearson79
Auto-up, at least for a period of time, was not legal in the US for safety reasons. However, you can buy a piece of hardware that will give you the auto-up feature, and it's a super easy, 15 minute install.
Old Jun 12, 2008 | 06:51 PM
mimini1's Avatar
mimini1
My 2002 did not come this way ,when it was delivered holding down the unlock button opened the trunk. The dealer had to program the windows and roof to open with the unlock button.So it is possible your car may not open the windows and roof if it has not been so programmed.
Old Jun 12, 2008 | 11:15 PM
ScottRiqui's Avatar
ScottRiqui
There are some errors in the first-gen owner's manuals that took forever to be fixed/updated. One is the "auto-up" for the windows (was never available on the US-spec cars). Also, the owner's manual says that you can store a different set of vehicle preferences in each key, and that was never true.
Plus, when MINI went with the larger wheel lug bolts in mid-2006 and changed the torque spec from 88 lbf-ft to 103 lbf-ft, the owner's manual for the convertible continued to list the old torque spec (at least for the 2007 model - I don't know about the 2008 manual).
iggi
18
Feb 9, 2026 01:00 AM
Svejk
Feb 24, 2019 12:18 PM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
