Tire question for this area
Most people end up switching to regular (non-runflat) tires once the stock ones are gone. The extremely high price of run-flats combined with the fact that a flat runflat is still a flat tire that needs replacing ASAP makes them very unattractive in the long run. However, if you get a flat in bad weather or in heavy traffic, the runflats can at least get you a few miles down the road to a safer place to deal with the problem.
Personally, I would go with the performance ones if I planned on "spirited" driving. But if I was just using my MINI as a commuter vehicle and didn't really care about maximum cornering or accelleration, I'd get the all-seasons since they will last a little longer. But no matter what, I'd switch to regular tires once I burned up the set that came on the car.
Run flats are noisy, expensive, and provide a harsh ride. If I'd known this, I would not have gotten them in the first place. My wife broke two of them on two separate occassions by hitting potholes at speed on the interstate. She was probably driving 65 to 75 mph. The first time it happened, the wheel also broke. It actully split down the middle. That time I had to get tire and wheel (used). Still though, the dumb tires are >$300 each.
After they wore out, I replaced them with Falken FK 452. They were about $80 each, provide a very nice ride, handle very well, and are quiet. Can't say that about run flats.
Oh, I use 17 inch wheels.
Thanks for the info guys. It sounds like I would much prefer regular to run-flats, but the configurator on the miniusa site only has them as an option on the MCS. Is there a way to get non-runflats on the MCS other than just ordering them and then switcing out when they wear out?
My current cooper has runflats and they are noisy, my new one that is ordered has stock tires
keep in mind if the runflats get a flat, you cant fix them you have to replace them:(
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
Mini'mon
Aug 16, 2015 04:15 PM
