R50/53 Inside chrome Q
Old Jun 9, 2008 | 11:10 AM
andrewholmes's Avatar
andrewholmes
Inside chrome Q
i have a swecond post out regarding thins but just wondered if anyone knows how to remove the tac plastic trim piece to replace with the chrome one? its sitting here and KILLING me not putting it on. thanx in advance
Old Jun 9, 2008 | 07:07 PM
ClintTheMiniOwner's Avatar
ClintTheMiniOwner
I believe they just pop off. Check for screw holes on the back side, if there are none, then its a pop off. The problem is trying not to damage it in the process. You have to get a little aggressive with plastic clips and tabs sometimes. Try a little hook tool and pull on it supporting on the back side so you don't break the whole unit. Sometimes you should also look for spots where you see a sign of a tab on the inside push downward and pull. There also may be spots intended for that-
Old Jun 9, 2008 | 07:09 PM
GP0256's Avatar
GP0256
I accidentally popped 2 of mine off so far just with a cup in the cup holder and the speaker cover with a light bump. They are both just pushed in with big plastic tabs if this helps!?!?!?!
USNAE2
16
Jun 17, 2022 07:17 AM
OutMotoring
Mar 3, 2017 06:29 AM
got_mini?
Oct 7, 2015 02:12 PM
Colt45Magnus
Oct 1, 2015 04:08 PM
potterstein
Oct 1, 2015 07:10 AM
