Drivetrain M7 DFIC and water sprayers
Old Jun 8, 2008 | 04:12 AM
D-MAN's Avatar
D-MAN
Does anyone have a water sprayer set up for their M7 DFIC?
The spray bar is no longer available, just interested to see if anyone has done a sprayer set up for it.
Old Jun 8, 2008 | 05:01 AM
scolburn79's Avatar
scolburn79
You can either hook it up to your rear washer pump or you can by the variable controller from snow and have it activate under Boost. if you do it that way then you will either need to put a third pump on your window washer or put another water tank in
Old Apr 3, 2010 | 11:06 PM
D-MAN's Avatar
D-MAN
This is what I ended up doing with my DFIC.
I installed a dual cryo spray bar system from dynotune
and a custom water sprayer that is hooked up to my piggyback ECU.
Shouldn't have any problem with heat soak anymore
Old Apr 3, 2010 | 11:25 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Sweet D-man that is the kind of enginewity I was talking about in my "So how much power do you think it will all be worth" thread, you just took it a little further with the Co2.
IMHO it will work great, but could still be better with an exit scoop.
Old Apr 3, 2010 | 11:29 PM
D-MAN's Avatar
D-MAN
Thanks Rick
The exit scoop works a treat.......here is a pic
Old Apr 3, 2010 | 11:55 PM
DICKS GARAGE R53
That looks awsome If only I could find all the nessicary parts here in the US to swap to Right side drive I would be a happy man
Old Apr 4, 2010 | 01:25 AM
fishead # 1's Avatar
fishead # 1
cowl vents
D-MAN...WHERE OH WHERE did you get those cowl vents ??? PUH LEEEZ !!! Are we wastin our time right now tryin to make some "acceptable" ones when somebody's ALREADY gottem ?? Me thinks~~~~~~YEAH~~~~~~~~~~~I'm on my knees & beggin PLEASE !! OBEY
USNAE2
16
Jun 17, 2022 07:17 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
ian260
Mar 29, 2017 06:08 AM
vulkandino
Oct 31, 2015 08:29 PM
martinb
Oct 7, 2015 05:00 PM
