Can I fix this? Cracked rim in R105 18
Old Jun 6, 2008 | 07:05 PM
TobCapone's Avatar
TobCapone
Hello,
Any chance a tire shop would be able to fix a cracked rim? I'm thinking no, but I'm no expert.
If I can't fix it I need to replace it and fork over big $$
Thanks for the advise.
Attached Thumbnails Can I fix this?  Cracked rim in R105 18-minitire.jpg   Can I fix this?  Cracked rim in R105 18-tirecrack1.jpg   Can I fix this?  Cracked rim in R105 18-tirecrack2.jpg
Old Jun 6, 2008 | 08:05 PM
hemiheaded18's Avatar
hemiheaded18
I doubt it. They would have to weld in the crack and bang out that lip somehow. Don't be surprised if everyone says no.
Old Jun 6, 2008 | 08:09 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
I don't know if it will be worth it in the end.....but you can easily find a shop that will weld that up for you....smooth it out....then spray it with some more clear. In the end it may be easier/cheaper to just buy another wheel though.
Welding cracked rims is pretty common though....so most wheel repair places should be pretty willing to do it
Old Jun 6, 2008 | 08:11 PM
hemiheaded18
But that crack is pretty close to that lip and it did push it out a bit. You think they could salvage that?
Old Jun 6, 2008 | 08:13 PM
Rally@StanceDesign
Yah...I think the bend would be pretty easy to remove...I've seen worse bends fixed. I think the welding/smoothing will be the hard part
Old Jun 6, 2008 | 08:17 PM
Striped Toad's Avatar
Striped Toad
Ive had several rims repaired (5 total) with dents and cracks, one about 6in long. You should be able to find a rim repair shop, well, i guess it all depends on your location, we are known as pothole city, so there are places around us. It ranged between 75-130 for 20" billets.
Old Jun 7, 2008 | 07:27 AM
coobah's Avatar
coobah
I used this place a few years ago and they were great!!!!!
I bent 2 of my TSW Hock R's and they "trued" the rims and refinished them, and all for cheaper than what 1 would have costs me to replace.
Good luck!
Ye Olde Wheel Shop, 6363 Washington Blvd., Elkridge, MD 21075, (800) 526-8260, (410) 796-8400
Old Jun 7, 2008 | 10:06 AM
TobCapone's Avatar
TobCapone
Thanks for the info
Thanks for the suggestions fellas. All the comments were very insightful.
I'm located in Los Angeles so I'll probably call around some rim repair shops and get some quotes.
Cheers.
Old Jun 7, 2008 | 02:08 PM
OctaneGuy's Avatar
OctaneGuy
I haven't used these guys yet, but I'm going to check them out next week to see if they can fix a flat spot on my rims.
http://www.wheel-repairs.com/
Richard
Cheers.
Old Jun 7, 2008 | 02:15 PM
Rally@StanceDesign
Richard
Good find....they look like a good shop. They even have an example of a repair where the damage looks just like yours but a little worse....so I'm sure they can fix your wheel
Old Jun 7, 2008 | 02:33 PM
PGT's Avatar
PGT
I think I'd have pulled the eject handles on that one myself, but if they could fix it safely, more power to them for doing it
hockeydad51
Oct 9, 2015 01:51 PM
DevilMeTaz
R60/R61 Stock Problems/Issues
Oct 2, 2015 06:44 AM
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
freckles81
Sep 8, 2015 09:48 AM
