R50/53 Who's got the cross drilled rotors?
Old Jun 5, 2008 | 03:28 PM
hexproject's Avatar
hexproject
anyone got the cross drilled rotors + big brake kit?
How's the performance?
Old Jun 5, 2008 | 03:59 PM
Guest's Avatar
Guest
They don't do anything... Buy regular rotors and spend the extra money on better brake pads.
Old Jun 5, 2008 | 04:15 PM
minimusprime's Avatar
minimusprime
this generalization is bs and leaves so much left to be desired it's not funny.
But to be fair it's a huge topic that would best be answered by reading a bit about brakes and how they function. From there you can determine if your requirements are such that a bbk is necessary. Chances are they are not.
p.s. unless they are insane carbon ceramic or oem porsche brakes... they are going to crack at the drilled holes.
Old Jun 5, 2008 | 06:05 PM
HighLife4136's Avatar
HighLife4136
Trying to take over as the Captain of the B.S. Police???
Old Jun 5, 2008 | 06:13 PM
Some Guy's Avatar
Some Guy
Just to help clear up potential misinterpretation... I think Rusty was saying taht Cross drilled rotors dont do anything, not BBK's which have been proven over and over as being useful in certain situations.
Old Jun 5, 2008 | 07:41 PM
JIMINNI's Avatar
JIMINNI
Yea your right, Porsche doesn't know anything:
Old Jun 5, 2008 | 10:34 PM
Guest's Avatar
Guest
I was talking about x-drilled rotors not big brake kits. I have a wilwood kit myself. I've had all of them, x-drilled, slotted, etc. Slotted wears pads out faster, other than that, no benefit in braking.
As far as a BBK goes, 99% of drivers on the street don't need one. Hell, the majority of drivers on the track don't either (Pad and fluid upgrade works fine). I had an opportunity to get one for about what it would have cost to buy new pads and rotors, so I jumped at it.
Old Jun 5, 2008 | 10:47 PM
Guest's Avatar
Guest
I think most brake experts have already ruled that x-drilled rotors are standard on porsches for much the same reason they are on most sports cars. It's come to be expected by the buying public, and it's more to add to their marketing BS. My statement was plenty valid, I've tested them on the track, the car doesn't fade any less with x-drilled rotors.
Slotting helped a bit with initial bite, but other than that, the fade characteristics were the same. Unless you have some actual data instead of marketing BS from Porsche about how awesome drilling holes in a rotor (How does removing 25% of the thermal mass of an object increase it's heat absorption characteristics?), don't bother.
Still don't believe me? Here's some info from people who PROBABLY know a thing or two about brakes...
From Stoptech:
Which is better, slotted or drilled rotors?
StopTech provides rotors slotted, drilled or plain. For most performance applications slotted is the preferred choice. Slotting helps wipe away debris from between the pad and rotor as well as increasing the "bite" characteristics of the pad. A drilled rotor provides the same type of benefit, but is more susceptible to cracking under severe usage. Many customers prefer the look of a drilled rotor and for street and occasional light duty track use they will work fine. For more severe applications, we recommend slotted rotors.
From Wilwood:
Q: Why are some rotors drilled or slotted?
A: Rotors are drilled to reduce rotating weight, an issue near and dear to racers searching for ways to minimize unsprung weight. Drilling diminishes a rotor's durability and cooling capacity.
From Baer:
What are the benefits to Crossdrilling, Slotting, and Zinc-Washing my rotors?
In years past, crossdrilling and/or Slotting the rotor for racing purposes was beneficial by providing a way to expel the gasses created when the bonding agents employed to manufacture the pads...However, with today’s race pad technology, ‘outgassing’ is no longer much of a concern...Slotted surfaces are what Baer recommends for track only use. Slotted only rotors are offered as an option for any of Baer’s offerings.
Then from Grassroots Motorsports:
Crossdrilling your rotors might look neat, but what is it really doing for you? Well, unless your car is using brake pads from the '40s and 50s, not a whole lot. Rotors were first drilled because early brake pad materials gave off gasses when heated to racing temperatures, a process known as "gassing out." It was an effective solution, but today's friction materials do not exhibit the some gassing out phenomenon as the early pads.
Contrary to popular belief, they don't lower temperatures. (In fact, by removing weight from the rotor, they can actually cause temperatures to increase a little.) These holes create stress risers that allow the rotor to crack sooner, and make a mess of brake pads--sort of like a cheese grater rubbing against them at every stop. Want more evidence? Look at NASCAR or F1. You would think that if drilling holes in the rotor was the hot ticket, these teams would be doing it...Slotting rotors, on the other hand, might be a consideration if your sanctioning body allows for it.
Cutting thin slots across the face of the rotor can actually help to clean the face of the brake pads over time, helping to reduce the glazing often found during high-speed use which can lower the coefficient of friction. While there may still be a small concern over creating stress risers in the face of the rotor, if the slots are shallow and cut properly, the trade-off appears to be worth the risk. (Have you looked at a NASCAR rotor lately?)
I have a friend with a 997 turbo with the 16k dollar carbon ceramic brake upgrade. Guess what, My car stops faster on R-Compounds! (More aggressive pads and stickier tires). They do look great though, and I'm sure they really shine on the track when you're doing endurance racing.
Here's a better picture by the way...
Old Jun 5, 2008 | 10:55 PM
Rascasse's Avatar
Rascasse
I have disagree. Better brakes will make a difference. When my 348 Challenge car's brakes were changed to an F40/F50 set up, I quickly found that I could outbrake virtually anything short of a purpose built race car, at the track. And on the street, there is nothing like having the confidence of great stoppers.
Old Jun 5, 2008 | 11:05 PM
Guest's Avatar
Guest
FYI, here are shots of Nascar and F1 brakes
Nascar:
Good friend of mine (Same one with the Porsche) works for an Indy Race team. VP of Marketing and Sales. I'd be happy to have him explain why you don't need holes in your rotors to stop faster.
Old Jun 5, 2008 | 11:10 PM
Guest's Avatar
Guest
People don't understand what's actually stopping the car. Brakes don't stop the car, they stop the wheels. The wheels have to be connected to the ground (Via tires) to stop the car. If you're activating ABS with STOCK BRAKE PADS, upgrading them isn't going to shorten stopping distances.
Upgrading rotors does nothing but increase thermal capacity. Upgrading pads increases the amount of brake torque your rotors can apply to the disk, basically, how hard it grabs onto them.
I ran race pads on the street as a precursor to a track day (wanted to bed them in). Aside from destroying my rotors (less than 300 miles and it actually ate THROUGH the machined slots in my rotors and wiped the rotor clean. Yes, that's right, my slotted rotors are now plain) there wasn't any decrease in stopping distances. All I did was activate ABS at every stop cause the wheels wanted to lock with almost no pedal input.
Yea, it was cool to rest my foot on the brake and slow from 60-30 in 2 seconds, but i'd rather not go through rotors every few months.
Old Jun 6, 2008 | 06:18 AM
hoonpv's Avatar
hoonpv
Although Rusty backed up on his statements with his sources, I do think
"They don't do anything" comment is a bit too generalized.
I believe slots and drilled rotors WORK in certain situations and there are certainly benefits to them, but for how most people drive on streets and tracking occasionally, it is better to spend money, like Rusty said, on better pads or rotors.
Old Jun 6, 2008 | 10:07 AM
slickfast's Avatar
slickfast
guys, guys. There is little to no STOPPING benefit with slotted or drilled rotors (though there are limited benefits if the edges aren't beveled, because of the added "bite" into the pad by the sharp edge. The primary reason slots and drills are used is for cooling. Keeping the temperature uniformly down with brakes is an eternal problem, and this is a way to help it. However, when conditions are under very high stress, its sometimes not worth adding all of those little stress concentrations. The real benefit comes in the relationship that the rotor and pad have. The coefficient of friction between the pad and the rotor as well as the rubber and road is the driving force (no pun intended!) behind stopping performance as far as stopping power Sorry about the nerdiness, its the only way i can talk about it!
That being said, i LOVE the look of slotted or drilled rotors, and since most of us are just street drivers, having the Thought of better performance is good enough to justify getting some sexy rotors
Old Jun 6, 2008 | 10:14 AM
slickfast's Avatar
slickfast
Actually, could you have him come on and explain?? I'm with you on this, but it's an interesting topic, and I would love to hear how he explains it
Old Jun 6, 2008 | 10:53 AM
big howe's Avatar
big howe
Nascar:
I agree with what you're saying Rusty, but with all due respect, let's be honest, no one is cross drilling carbon-carbon rotors(F1) Doesn't really relate to the discussion of iron discs.
Old Jun 6, 2008 | 11:55 AM
Guest's Avatar
Guest
True, but even still, Indy hasn't used drilled rotors since outgassing stopped being an issue (Even before Carbon Ceramic brakes).
I'll see if he'd be willing to come on and explain, I asked him to snap a few pics of the rotors if he had a chance today, he's in TX right now for practice and qualifying.
Wish Roth Racing luck!
Old Jun 6, 2008 | 11:57 AM
Guest's Avatar
Guest
Sounds about right, but thermal benefits with x-drilled and slotted had more to do with pad boundary layer "out-gassing" than actually cooling down faster. Removing thermal capacitance from the rotor via mass reduction doesn't help with heat dissipation.
Old Jun 6, 2008 | 12:05 PM
big howe's Avatar
big howe
Damn Rusty, you must have a PC wired right into you're central nervous system. Not a few clicks goes by without you being back with a response on this forum.
Like I said, I agree with you, the carbon disc just made me laugh.
I have to admit, I have drilled rotors, but thats what comes with the AP kit(the price was too good to pass up) and the heavy cabrio will be lucky to see a track day. That's what the other money pit is for.
Old Jun 6, 2008 | 12:15 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Additional recent NASCAR pics from the Rousch/Fenway shop... because they're cool.
Old Jun 6, 2008 | 12:33 PM
fishey72's Avatar
fishey72
This discussion is way above my level....but the only thing that has been described as a positive for x-drilled/slotted is if you do a lot of stop/go city traffic and glaze over pads. The extra cheese grater effect helps keep the surfaces fresh, and extra pad replacement!
Otherwise I just upgraded the fluid, pads, SS-lines, bushings, and plain ole rotors. Need better tires.
x-drilled do look cool, gotta admit. bling!
Old Jun 6, 2008 | 01:14 PM
AutoXCooper.com's Avatar
AutoXCooper.com
Old Jun 6, 2008 | 10:33 PM
Guest's Avatar
Guest
Well, here's the response I got back from my Indy buddy. He actually said they DO use plain iron rotors for road courses. They definitely don't use x-drilled though for anything (This is for IndyCar).
Old Jun 6, 2008 | 10:40 PM
Guest's Avatar
Guest
I was gonna say, the cheese grater effect isn't something that helps me with anything other than replacing pads often!
ericbryant24
55
Sep 30, 2024 02:10 PM
Filmy
15
Jun 6, 2023 06:27 AM
Sep 14, 2015 12:48 PM
David.R53
Sep 13, 2015 03:44 PM
Sep 11, 2015 01:15 PM
