Confirm torque spec on brake caliper bolts?
Old Jun 5, 2008 | 07:59 AM
rwkeating's Avatar
rwkeating
Would someone confirm that the torque spec of the 2 bolts that hold on the brake calipers (2006 MCS stock brakes -not JCW) is:
rear 48 ft/lbs,
front is 81ft/lbs?
81 sure feels like a lot to me, so I just want to verify it before cranking it up to that.
Thanks in advance
Old Jun 5, 2008 | 08:02 AM
toddtce's Avatar
toddtce
These specs would be for the caliper mount cage to the spindle. Not any smaller slider pin bolts.
Fronts M12 bolts (bolt size, not socket size)
Rears M10 bolts " "
Both specs appear well within proper range.
Old Jun 5, 2008 | 08:10 AM
rwkeating's Avatar
rwkeating
Just to be clear, I changed brake pads only, so I just removed the caliper (two 7mm allen socket size). Those are the ones I am interested. I didn't remove the other part that you need to remove to change the rotors.
This is the top one in the picture.
Sorry, my brake part terminology isn't up to par.
Old Jun 5, 2008 | 08:58 AM
toddtce's Avatar
toddtce
And that's why I mentioned it...You'd snap those in a heartbeat. The specs you are referring to are for the mount bolts- to the right of your arrow. Red arrow are perhaps "guide pins" in the book text?
Old Jun 5, 2008 | 09:13 AM
rwkeating's Avatar
rwkeating
Thanks for your replies Todd. Good thing I never even got those close to those specs!
Just to tie off this thread, I did more searching and it looks like these are the correct specs:
guide bolt (7mm) : 25-30 nm (so thats about 19-22 ft lbs)
Old Jun 5, 2008 | 11:38 AM
aem421's Avatar
aem421
Here ya go...
File Type: doc
Old Jun 5, 2008 | 05:52 PM
rwkeating's Avatar
rwkeating
aem421,
Thanks. That looks official . Where did it come from?
Old Jun 5, 2008 | 05:54 PM
aem421's Avatar
aem421
I have the Service Manual from BMW. It includes every BMW up to and including the R56.
Old Sep 18, 2017 | 08:54 PM
Subw00er's Avatar
Subw00er
reviving this old thread..
I tried torquing the rear caliper mount bolts to 110nm (81.13ft-lbs) as listed in that doc aem posted, but that must be for the front only - I actually stretched the bolt getting it in there, stopped turning because it didnt feel right! So glad it didnt break. It should be 48ft-lbs for the rear, right?
Old Sep 19, 2017 | 06:24 AM
rwkeating's Avatar
rwkeating
From the Bently Manual: The bolt that bolts the bracket on (collar bolt) is 81 ft-lbs for the front brakes and 48 ft-lbs for the rear.
Old Sep 19, 2017 | 06:14 PM
Subw00er's Avatar
Subw00er
Thank you!
Fwiw, the rear bolts are m10x30mm, 1.5 pitch.
Old Jun 21, 2018 | 06:54 PM
HZBJCW's Avatar
HZBJCW
How about for the JCW in the front? The caliper is directly bolted to the hub assy so is it 81 ft lbs?
Old Jun 21, 2018 | 08:12 PM
rwkeating's Avatar
rwkeating
The Bentley manual doesn't give a torque spec for the JCW for that bolt. It does list it as an M12 x 1.5. Since that is the same size as on the non-JCW, I would imagine that the torque would be the same (81ft-lb)
minipopkart
Aug 13, 2015 05:22 AM
minipopkart
Aug 9, 2015 12:13 PM
StealthR53
Aug 8, 2015 10:59 AM
