Suspension KW V1 coilovers and 5mm spacer
Old Jun 2, 2008 | 02:00 PM
rstalter77's Avatar
rstalter77
I'm about to purchase a set of KW V1 coilovers and was just wondering if any one knows if the stock 17" Flame wheels will fit w/o spacers. I just want to find out before I install them and them find out they need spacers. Thanks
Old Jun 4, 2008 | 07:30 AM
Ryephile's Avatar
Ryephile
Based on others having stock wheels with KW V1 and needing 5mm spacers, you probably will too. I don't have 1st hand experience [yet] with these coilovers, so take this advice with a grain of salt. When you get the coilovers in your hand though, you can do some measuring before installation to see if you'll have interference compared to the stock struts.
Let us know what you find!
Old Jun 4, 2008 | 12:18 PM
rstalter77's Avatar
rstalter77
Thanks Ryephile do you know if the H&R Street coilovers have the same issue?
Old Jun 6, 2008 | 07:21 PM
D Unit's Avatar
D Unit
How much did you get quoted for the kw1? I got quoted $1316 shipped. Please let me know.
Old Jun 7, 2008 | 10:09 AM
JDR's Avatar
JDR
What is your et?
Old Jun 7, 2008 | 10:56 AM
D Unit's Avatar
D Unit
I found this info on the web...
benzamg
R97 Flame-spoke ET48 22.0lb (10.0kg)
So, is it safe to assume that if someone is using aftermarket wheels with an offest below 40 that they would NOT need spacers?
Old Jun 7, 2008 | 12:16 PM
JDR's Avatar
JDR
benzamg
I *think it depends on the wheel width and a bit on the tire you are using too. someone correct me if this is wrong please.
at any rate you would be best getting a measuring tape and seeing where everything will sit unless you can do a test fit.
Old Jun 7, 2008 | 02:51 PM
rstalter77's Avatar
rstalter77
D Unit call Euro Styles East they are a big distributer of KW. They quoted me $1254.00 Shipped. They said the R56 part #s would be on there website sometime this week. Talk to Dave
www.esetuning.com
Old Jun 7, 2008 | 09:03 PM
D Unit's Avatar
D Unit
www.esetuning.com
This is exactly the type of info I was looking for. This is definitely cheaper than the lowest price I could get... Thanks a lot!
YaTuSabe
Aug 23, 2018 11:41 AM
RIchard Nguyen
Sep 14, 2016 11:43 AM
CooperSharp
Oct 12, 2015 09:21 AM
GAT
Oct 4, 2015 07:27 PM
Zew2888
Sep 29, 2015 08:49 PM
