R56 Will Auto in Sport Mode Shift Into 6th Gear?
Old Jun 1, 2008 | 04:41 AM
ldye's Avatar
ldye
I've run up to 85 mph will in the sport mode and the tranny stays in 5th. I've not found anything in the manual reference to this.
Old Jun 1, 2008 | 04:49 AM
Krafty04's Avatar
Krafty04
I think you'll have to run it up quite a bit higher, but not sure if it will still shift to the last gear before the speed limiter cuts in. I can hit the 155mph in my 335i in 5th gear and don't need the 6th gear, it's only for mpg on the highway. My normal driving 60-80mph and in sport mode step, the bimmer never leaves 4th.
I wish my MCS was here so I could go check for ya...cause I would.
Old Jun 1, 2008 | 05:08 AM
jw34's Avatar
jw34
Yeah I've never really pushed it, but it always seems to say in fifth for me. I end up just going to the manual shift Sport and put it into 6th.
Old Jun 1, 2008 | 05:15 AM
emtrey's Avatar
emtrey
when its in sport mode, fifth is your top gear. However, if you run in manual shift mode, you can upshift to sixth with a lever tap.
I run mine like this most of the time. I do not find the extart weight of the steering that big a difference and the manual shift mode is more flexible than using sport mode.
09R56
Nov 16, 2022 10:49 AM
kurosh
Aug 27, 2015 11:54 AM
nomar116
Aug 10, 2015 11:24 PM
xpunisherx
Aug 10, 2015 10:50 PM
