R56 Will Auto in Sport Mode Shift Into 6th Gear?
I think you'll have to run it up quite a bit higher, but not sure if it will still shift to the last gear before the speed limiter cuts in. I can hit the 155mph in my 335i in 5th gear and don't need the 6th gear, it's only for mpg on the highway. My normal driving 60-80mph and in sport mode step, the bimmer never leaves 4th.
I wish my MCS was here so I could go check for ya...cause I would.
when its in sport mode, fifth is your top gear. However, if you run in manual shift mode, you can upshift to sixth with a lever tap.
I run mine like this most of the time. I do not find the extart weight of the steering that big a difference and the manual shift mode is more flexible than using sport mode.
09R56
11-16-2022 10:49 AM
07-16-2020 12:54 PM
kurosh
08-27-2015 11:54 AM
