Suspension Who makes the best anti-mushrooming plates?
Old May 31, 2008 | 04:29 PM
duality's Avatar
duality
I want to order some right now. what/where to get?
Old May 31, 2008 | 05:19 PM
OldRick's Avatar
OldRick
No-one makes the best anti-mushrooming plates, as the best ones would be inside the shock tower between the strut and the sheet metal, where they would do some good...
Old May 31, 2008 | 06:16 PM
duality's Avatar
duality
an answer of "no" doesn't really answer the question.
Old May 31, 2008 | 06:18 PM
CR&PW&JB's Avatar
CR&PW&JB
I have one set made by Craven and another made by M7. I really don't believe there's any discernable difference between them... nor any of the other plates made by reputable manufacturers.
Old May 31, 2008 | 06:54 PM
miminut's Avatar
miminut
From: Half Moon Bay California, 25 miles south of SF on the coast
do a sandwich job
Buy the Ireland Engineering Fixed Camber Plates and any SRP of your choice. The strut top will not deform sandwiched between these two items. With this setup you could drive on the pot holed streets of Chicago with impunity.
Old May 31, 2008 | 08:07 PM
JGS's Avatar
JGS
I have the Craven STD's on order...M7's are reportably also similar.
Old May 31, 2008 | 10:13 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
+1 on sandwiching them, but get adjustable camber plates because camber doesn't always match right to left. It is nice to be able to get them even with adjustability.
Old May 31, 2008 | 10:42 PM
heyduard's Avatar
heyduard
+1 for the IE fixed plates. they utilize a beefier bushing from a heavier car. And you get extra negative camber goodness.
Avoid potholes in any case, as the mini only has 2 inches of travel. deep potholes are no fun no matter what.
Old May 31, 2008 | 10:58 PM
UKSUV's Avatar
UKSUV
LOWES! They make this thing called a mallet....
Old May 31, 2008 | 11:35 PM
Nitrominis's Avatar
Nitrominis
Ditto on the Carven or m7. And avoid pot holes.
Old Jun 1, 2008 | 08:06 AM
AutoXCooper.com's Avatar
AutoXCooper.com
I have the M7's and love them. The IE plates would also help.
Old Jun 1, 2008 | 11:07 AM
rjtrout2000's Avatar
rjtrout2000
I have the M7 plates and have had no complaints. TSW also makes some camber plates now that look super beefy. Give them a look as well!
Old Jun 1, 2008 | 03:37 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Using a mallet to fix the mushrooming is ok, but only if you then add camber plates or the M7 plates, or both. The metal was deformed once to become mushroomed, pound it flat, and it's been deformed twice. It will be more likely to deform again without reinforcement, using only new stock parts is not enough to keep mushrooming away.
Old Jun 2, 2008 | 04:16 PM
UKSUV's Avatar
UKSUV
Thnaks for killing my joke...
Old Oct 31, 2008 | 07:47 AM
Wake|MCS's Avatar
Wake|MCS
Mushroomed towers just means a lower ride height up front
Old Oct 31, 2008 | 07:58 AM
checkmate2006's Avatar
checkmate2006
exactly the car just wants to be LOW not all 4x4ish
Old Oct 31, 2008 | 08:40 AM
OldRick's Avatar
OldRick
These are now available, and are probably the most effective reinforcement plates available, as they sit under the tower, where the stress comes from, instead of on top of it:
http://www.mini-madness.com/index.as...ROD&ProdID=334
Old Oct 31, 2008 | 12:08 PM
batrugger's Avatar
batrugger
I have a set of the red Cravens I'll sell for $110 shipped. They have been on the car for three months. The only reason I'm selling them is I want black ones.
Old Nov 19, 2008 | 08:33 PM
Car54's Avatar
Car54
Still selling? Top and bottom, or just tops for sale?
Old Nov 19, 2008 | 08:44 PM
PatM's Avatar
PatM
Does this happen on all MINI years? Even late model like 08 and 09? If one is to be as careful as possible and avoid as many pot holes as possible does this mushrooming still happen just given enough time?
We don't have a lot of large potholes in the Washington due to our mild weather (although there are some depending on where you drive.) and I have not heard from a lot of locals that this happens. But being new to MINI's (still waiting for delivery.) I may not have all information yet.
Any more heads up on this would be appreciated.
Regards,
Pat
Old Nov 26, 2008 | 07:31 PM
chad1140's Avatar
chad1140
I think that the biggest problems come from running larger wheel combos, cause I have hit some holy hell potholes in NYC that have damaged the wheel (they just run out in front of you here) and the towers were fine. I do have the M7 braces. It really makes me think as to what kind of holes people are hitting to end up with the super Mario shroomage.
Old Nov 26, 2008 | 08:04 PM
OldRick's Avatar
OldRick
It doesn't have to be much of a pothole if you hit it during a turn, when the suspension is already partially loaded on the outside wheels.
The issue is how often you bottom-out that 2" of first-gen suspension travel (or less if lowered), and how heavy a wheel you hit the tower with.
It also seems to vary by car - I was surprised to find noticeable mushrooming after 50K miles on my Mar.`05 build, even with light 15" wheels and very few potholes (Oregon roads).
Old Dec 8, 2008 | 03:07 PM
AZblackOUT's Avatar
AZblackOUT
I had a buddy who straight up welded 3/4 inch thick steel plating to the top of his strut tower...He did make holes for the bolts and the camber adjustment...
His reasoning to me was that STBs are only reinforced on the same 3 bolts that the strut is held with...to maximize strength, you need to utilize the sidewalls that are around the strut tower... They came out bada$$ but not my cup of tea at all. just a thought if you have the ability to do something like that or know someone who can.
Old Dec 11, 2008 | 12:19 PM
GOTCURVES's Avatar
GOTCURVES
I personaly had a fair amount of mushrooming on my stut towers. I flattened everything out and installed the M7 FSTB and for added reinforcement I installed the Helix BEEFY adj camber plates. Now I have 1/2" of billet machined alluminum both above and below and have had no signs of mushrooming since. Like Nabeshin said having the adjustment at hand makes for a very precise allingment as far as camber goes. Best case is to reinforce top and bottom BEFORE any mushrooming happens.
Old Dec 20, 2008 | 03:35 PM
curi0usmind's Avatar
curi0usmind
Just installed the Mini-Madness strut tower plates recently. Hopefully this is the end of my mushroomed towers.
Attached Thumbnails Who makes the best anti-mushrooming plates?-img_0088.jpg   Who makes the best anti-mushrooming plates?-img_0092.jpg   Who makes the best anti-mushrooming plates?-img_0093.jpg
Last edited by curi0usmind; Dec 22, 2008 at 09:54 PM. Reason: Wrong Vendors Name. Actually Mini-Madness.
