Navigation & Audio Bluetooth, iPhone, and Voice Commands
Old May 31, 2008 | 10:46 AM
ahendy's Avatar
ahendy
So I got my iPhone paired with my Clubman, and it seems to work okay. I can access my phonebook by pressing the "A-Z" button and choosing a name. However if I press the voice button and say "Dial Name ......." it talks back, "The phonebook is empty"
What's the deal?
Old May 31, 2008 | 12:39 PM
TWISTER's Avatar
TWISTER
The MINI has its own book that you need to add voice commands to
Old May 31, 2008 | 05:31 PM
Minidrivr's Avatar
Minidrivr
Certain phones like the Razr will voice dial without building a phone book in the Mini itself. There may be others as well. The iphone isn't one of them though.
Old Jun 3, 2008 | 01:14 PM
sbeard's Avatar
sbeard
I have exactly the same problem that ahendy has and I'm afraid I'm too dense to understand the two responses that were posted. My 08 MCS is about 2 months old and I successfully voice dialed on one occaision, but since that time I too get the "The phonebook is empty" reply.
Is there a fix? Thanks for any help.
Steve
Old Jun 3, 2008 | 01:20 PM
COOP310's Avatar
COOP310
The iPhone will not simply dial from your phonebook. You will need to add each number to the voice dialing phonebook using the instructions in the manual so that the MINI recognizes the voice prompt. (I think that the command was "add name") It can be a bit tedious and you may not want to add all of your contacts.
Old Jun 3, 2008 | 01:24 PM
sbeard's Avatar
sbeard
I'll give that a try. Thanks!
Steve
Old Jun 4, 2008 | 09:29 AM
ahendy's Avatar
ahendy
Yup, that's the ticket! "Save Name", and follow the prompts, and then say "save" and that's it!
It's too bad it doesn't dial out of the iPhone phonebook, but it's not a big deal. It works well this way, it's just initially a pain to add voice names for your whole phonebook.
Old Jun 5, 2008 | 08:14 AM
sbeard's Avatar
sbeard
Thanks to all who replied. I did the "Save Name" command and entered the numbers etc. Everything works as advertised now. Now I just have to enter all the important numbers I normally use.
Steve
PelicanParts.com
May 14, 2026 04:59 AM
minimofo
Dec 26, 2015 12:03 PM
rikaro
Nov 24, 2015 02:05 PM
PelicanParts.com
Accessory Products
Oct 1, 2015 01:23 PM
