R56 Do 16" Konig Feather fit an R56?
Old May 30, 2008 | 11:27 AM
D Unit's Avatar
D Unit
I had my cousin from Wheel Works call their Konig rep and the Konig guy said the 16s won't fit?!?! I've been inspired getting these rims after I saw an R53 have the 16" version, but can apparently the tech said they wouldn't clear the brakes or something.
When I got to KonigWheels.com, they wheel fit application says they fit. Also, Alta sells them on their website for the r56, but I would like to know if someone actually has them on their car or not in the 16" version. Please let me know and I would really appreciate it. I've been searching, but most people have 17s on their r56.
And the car that inspired me...
Old May 30, 2008 | 01:09 PM
STLMINI's Avatar
STLMINI
Doesn't make sense. The standard wheels that come on the R56 are 16"
Old May 31, 2008 | 08:26 AM
Boxcars's Avatar
Boxcars
Hi
Might be an offset issue.
I've been looking at these as well for my R53 in 17". and the offset is 38 or 40, can't remember. I think i found that my stock s-lights are 48 offset, might make enough diffence to rub??
I hope not cause looking at that pic of the pepper white is definately inspiring!
boxcars
Old May 31, 2008 | 08:29 AM
Boxcars's Avatar
Boxcars
hi
I also just remembered that the R56 has a larger lug bolt size , and some rims need to be drilled out....not a rub but another obstacle if trying to fit on an R56.
boxcars
Old May 31, 2008 | 08:55 AM
pauliekeys's Avatar
pauliekeys
I would call Alta and ask them if they will fit on your car. I'm sure they've test fitted these wheels on a R56 if they sell them for that model. The R56 has a 14mm lug hole which could be the problem of fitting on an R56. My 05 R53 has a 12mm lug hole which is stated above !
Old Oct 13, 2008 | 06:00 AM
jmsamr's Avatar
jmsamr
I know this is an older thread, but what was the answer?
I would like to get some black Konig feathers also 16". Where is the best place to buy the Konigs from?
Old Oct 13, 2008 | 05:46 PM
iwashmycar's Avatar
iwashmycar
sounds to me like you just need to drill out the lug holes a bit.
anyone have offset information? could be helpful later... i know i'll need it
Old Oct 13, 2008 | 06:03 PM
Oxybluecoop's Avatar
Oxybluecoop
Konig Feathers have a 40mm offset,weigh 15.2lbs and will fit an R56.Alta has both the 16" and 17".
Old Mar 19, 2009 | 04:00 PM
irishpunk's Avatar
irishpunk
I purchased black 16" Feathers from Alta and they fit my 2007 R56 "S" perfectly over the brakes - they do stick out from the wheel well "slightly" (10-30 mm?) with 215s on, which might be an issue with lowering springs. Call Alta and check - i they cannot answer your question satisfactorily buy something that you know does work perfectly. I am very happy with the slightly "bulgy" look.
Old Mar 19, 2009 | 04:34 PM
JudgeS's Avatar
JudgeS
do they rub at all?
Old Mar 19, 2009 | 04:45 PM
irishpunk's Avatar
irishpunk
Absolutely ZERO rubbing with 215/50R16s on the Feathers from ALTA - not even with four people (750lbs. of humans).
srhodes
Oct 8, 2015 05:17 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:19 PM
Aug 11, 2015 12:18 PM
