R50/53 Engine component interchange??
Old May 28, 2008 | 07:27 PM
tgmedin's Avatar
tgmedin
Are the lower end engine components of the supercharged and non-s/c engines interchangeable??
I have a 2003 MCS with a possible lower end problem and I may be able to pick up a non-S motor very reasonable for parts if I can use them. If not, which way should I proceed, a take out, a reman unit or just rebuild the engine currently in the car?
If I rebuild the existing engine what mod's should I make at that time??
Any help is greatly appreciated,
Thanks,
Tom in PA
Old May 28, 2008 | 07:35 PM
Dr Obnxs's Avatar
Dr Obnxs
No...
The crank is different, the con rods are different, and the pistons are different. There are no oil squirters in the Cooper short-block either.
Anyway, rebuild is the way to go. Others can help here, I don't have direct experience with it. Also, you could stroke the motor. Contact Jan at Revolution Mini Works (see the vendor directory) to see if your engine is a good candidate.
Matt
blackie
Jan 18, 2017 09:56 PM
Aug 21, 2015 11:25 AM
Mikal68
Aug 13, 2015 07:10 AM
Aug 12, 2015 01:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
