Cooper (non S) Modifications specific to the MINI Cooper (R50).
Rattle... help please (front end, driver side?)
Old May 25, 2008 | 11:03 PM
Keep Up's Avatar
Keep Up
So me and my roommate were driving around and i started leaving a redlight, slowly, not like racing or anything like that, and it made a knock, sounded like it came out of the front left corner of the car.
-it did not jump out of gear
-everything seems to drive fine
-kinda sounds like a shock rattle or something
didn't do that loud knock again, but i did notice that I hear the rattle more when the fans are kicked on, so i guess when the engine is working harder or whatever.
I opened the hood to try and locate it and could not due to the tightness
any suggestions or ideas, i read about the clutch/flywheel problem and don't think that is it, this was at 9pm on a warm night
Old May 26, 2008 | 10:49 AM
blue_bomber's Avatar
blue_bomber
maybe check under the car
maybe a suspension peice broke loose all of a sudden... but i would check everything best as possible. engine/tranny mounts, sway bar and end links, brake calipers, strut housings etc.
good luck with sourcing the noise, we all know how annoying the little things can be.
Old May 26, 2008 | 02:57 PM
Keep Up's Avatar
Keep Up
Well I put it up on the car lift and got it to do the rattle but my dad nor I could locate it... im wondering if it's an engine mount.
Where are all the engine mounts on this car? the rattle I hear is somewhat close to the battery, but sounds a little "lower" or "deeper" in the engine.
It made the loud knock again when I was leaving a redlight again in 1st gear, but I did notice i was kinda ridding the clutch out.
anymore suggestions would be awesome
thanks for the input BB
Old May 29, 2008 | 06:28 AM
Darkness's Avatar
Darkness
Check the heatshield on the exhuast system. There are two pieces (header and cat back) that meet together and overlap and will make quite a racquet but it will sound like its coming from the top of the engine. Just bend them apart so they aren't touching.
boostedhaze
Jan 2, 2018 07:26 PM
silence2-38554
Nov 12, 2015 09:39 AM
maestro39
Oct 27, 2015 02:38 PM
messyjesse96
Aug 12, 2015 05:51 AM
