Navigation & Audio Garmin GPS Mount
Old May 25, 2008 | 05:34 PM
amrbme's Avatar
amrbme
Garmin GPS Mount
Hey, I am new to the forum. I wanted to find out of there was a mount for a Garmin NUVI 350. I have seen the one that mounts to the left of the tach but wasn't sure where to get one.
Old May 25, 2008 | 06:49 PM
DAVESTER's Avatar
DAVESTER
take a look at kudausa.com for a great mount for a garmin
Old May 25, 2008 | 06:57 PM
Mini Fireman's Avatar
Mini Fireman
The one to the left of the tach is available from the dealer. You can buy the mount with wiring harness for $175 I believe.
Old May 25, 2008 | 07:13 PM
jearl's Avatar
jearl
Maybe this is because I switch my Zumo from my motorcycle to my MINI, but isn't there a suction cup mount that comes with the unit? That's what I use and it's perfect for my needs when I need GPS on four wheels.
Old May 26, 2008 | 06:04 PM
amrbme's Avatar
amrbme
Garmin GPS
I think the Kuda is for the 06 or earlier. I have an 07 S Hardtop. I'll check with the dealer.
Old May 26, 2008 | 06:09 PM
MC 2's Avatar
MC 2
You can make your how if u are good whit your hand.. chek my gallery
MC 2
Old May 26, 2008 | 06:25 PM
SPF ZERO's Avatar
SPF ZERO
Kuda has mounts for 1st and 2nd generations.
Old May 26, 2008 | 07:15 PM
Mini Fireman
They make them for the R56 also: http://www.kudausa.com/kuda_mount_an...07-34-529.html
Old May 26, 2008 | 07:52 PM
MINIBee's Avatar
MINIBee
The Kuda is great. It looks OEM and doesn't get in the way at all. The MINI OEM mount doesn't give your passenger any access to the NAV.
Old May 26, 2008 | 07:55 PM
Newdl's Avatar
Newdl
The MINI one is GREAT!!!! I love it but it was kind of expensive....and not a really easy DIY
Old May 26, 2008 | 08:37 PM
playtowin's Avatar
playtowin
If you look at this thread there is a lot of info about the Garmin Nuvi 360 OEM bracket:
https://www.northamericanmotoring.co....php?p=2143090
You can find out where to get it at a discount, how to install it, and pics.
Old Apr 11, 2009 | 05:06 PM
3nigma's Avatar
3nigma
Which specific Kuda parts would I need to order for my 09 JCW Mini, to install a Garmin 460W on the left side of my tach?
Old Apr 11, 2009 | 05:39 PM
howsoonisnow1985's Avatar
howsoonisnow1985
ebay has Kuda too.
I also bought a Garmin car charger and suction/windsheild mount for when I use rentals or others drive, but the conveniance of mount made me use it on MINI too.
Old Apr 11, 2009 | 05:41 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
www.Cravenspeed.com
watch the video: https://www.northamericanmotoring.co...-revealed.html
They have a nice set up which attaches to one side of your tach.
And you can add a mount on the other side to add other components as well.......
Old Sep 15, 2010 | 01:34 PM
ERIK_MTL's Avatar
ERIK_MTL
To resurrect a thread from the dead. I'm returning my lease, and it has the bracket installed, so I want to remove it so I can potentially install it in a new car.
The dealer installed the bracket, so I'm curious as to how much I should remove, such that when I get a new car I can get it installed again, not missing any parts.
Does X9002 stay on the car? Should there be a 'cover' that I install when I remove the wiring harness?
Are the screws longer than stock/I should get new/shorter ones to replace them when I return the car?
File Type: pdf
Old Sep 15, 2010 | 04:11 PM
Contessa's Avatar
Contessa
Use the bean bag
Garmin has a bean bag you just set on the dash. It comes with a mount and then you can put it anywhere you want ...even in a (gulp)rental car
Old Sep 15, 2010 | 08:16 PM
mbu's Avatar
mbu
Originally Posted by MINIBee
...The MINI OEM mount doesn't give your passenger any access to the NAV.
That's the problem I found with most mounts, so.... I made my own! Both the passenger and the driver can see it very easily!
Photo 1:
The mount was machined from a piece of solid aluminum to match the contour of the Mini's speedometer. A ball was made to fit a typical Garmin mount.
Photo 2:
The mount painted and then installed with double sided tape.
Photo 3:
GPS Unit installed.
Old Sep 16, 2010 | 02:25 AM
howsoonisnow1985
Its ugly but, works the best
Old Sep 16, 2010 | 04:04 PM
t0m's Avatar
t0m
I've done this install once with the old style, and once with the new style, so I'll try to hit your questions based on my memory of the install.
The kit installs into the X9002 harness using adapters. You have to pull the correct wire and pins from the harness, and then insert them into the splice adapters. You should be able to carefully disassemble these and put them back into the factory harness. Just make sure you line up the correct colored wires into the right slot in the harness.
The screws that come with the kit are longer than the original screws. They probably wont fit back in without the bracket installed, but I'm not sure. You can also probably take the screws out and use them to go to a hardware store and find a shorter screw with the right thread.
If you try to install in a new car, most of the kit should work, but you may have to get new parts for the plastic parts that are used to connect the OEM harness wires. I'm not sure of the correct term, but you'll know what I'm talking about if you take it apart. If you are really careful removing the wiring, you'll be able to reuse them.
Hope that helps.
Old Sep 17, 2010 | 10:57 AM
36rodder's Avatar
36rodder
From: I live in Webster, NY (just east of Rochester)
A different spin on mounting a GPS
I want to install my Garmin but didn't want it hanging off my dash or stuck to my window because it has a tendency to attract thieves to break into your car even if the unit isn't mounted. They assume that if there is a mount there the GPS is probably somewhere in the car. I mounted mine in the empty space under the window switch assembly.
Advantages:
-- Unused space anyway
-- Gives it a built in look
-- Not noticable to someone walking by the car even with the GPS in place
-- Power port is right there, no wiring to do, just plug it in - Turns off autmatically when you turn the car off since this is a switch plug.
-- No glare in bright sunlight
All I did was attach a piece of smooth plastic across the back of the down tubes and mounted the GPS to that using the windshield suction cup. Perfect!
'02 Liquid Yellow MCS
Old Sep 17, 2010 | 02:04 PM
MINIdave's Avatar
MINIdave
The problem I have with putting it down low like that is that it takes your eyes so far off the road to see the display, also it would be impossible to input anything - which you're not supposed to do anyway.
Since I use mine as a speedo, I like it up in the line of sight.
Old Oct 24, 2010 | 10:24 PM
kt750's Avatar
kt750
I know not many people a big fan of putting the gps unit below but I found this for those who're interested...
http://cgi.ebay.co.uk/ws/eBayISAPI.d...ht_2274wt_1208
It should work pretty well, no splicing, just stick it up the jack and should be good....
Just ordered one, and we shall see how it goes.
Advantages:
Filmy
15
Jun 6, 2023 06:27 AM
elverado
Jan 18, 2022 02:51 AM
minimofo
Sep 30, 2015 12:26 AM
TREX
R58 :: Coupé Talk (2012+)
Sep 5, 2015 02:59 PM
Sep 4, 2015 02:34 PM
