Drivetrain Alta CAI Lid Problem
Old May 23, 2008 | 05:51 PM
Silent1's Avatar
Silent1
So i've just fitted the Alta CAI and Lid.
Before i put the lid on, the filter 'neck' fitted snugly up to the black wall of the filter housing.
Once i put the bracket on for the lid it stood away from the wall by about 1/2", when i looked at the photo for the lid install it shows the filter with one jubilee clip, whereas on mine it's got 2.
One for the filter - wall connection, the other is for the foam to connect to the inner metal housing.
It seems that this second jubilee clip is stopping the bracket fitting properly, as a result the lid is on, but there's a 5mm air gap between the front wall (where the filter attaches) and the top of the lid because it's set too far back.
Old May 23, 2008 | 10:28 PM
ninjlao's Avatar
ninjlao
Ninja Mini
If this is what I think it is then I had the same issue. I had to do a little creative bending of the bracket so that the lid wouldn't push the bracket which in turn pushed the filter off.
Old May 24, 2008 | 02:59 PM
Silent1's Avatar
Silent1
That's what i did in the end, hacksawed the end of the bracked off and fitted it properly.
:( It doesn't bode well, especially as my ALTA Catch Can turned up without the 2 right angle push lock fittings for the sight tube, meaning i can't use it.
Teh
Aug 22, 2022 04:37 AM
AWOL
Mar 28, 2016 10:51 AM
Mini7
Feb 2, 2016 07:52 PM
stierzy34
Sep 15, 2015 04:40 PM
speedbird_1
Aug 15, 2015 04:44 PM
