R56 When is the first Free oil change?
wow, that is gonna be a really long way, i have 9100 miles, and the indicator shows 10,000
does that mean until 19,100 or 1 year, whichever comes first.
over 15,000 miles is a really long way to go before the first oil change. i am gonna have to change it myself sooner then. probably when it reaches 10,000 miles
Are you sure you're reading that mileage-to-maintenance indicator correctly ? The first maintenance should be around 10-12,000 miles on the odometer.
Unless you drive like an old lady, and I seriously doubt you do, there's no way your MINI should go to 19,000 miles before the first maintenance/oil change.
Put your reading glasses on and read it again. I'm thinking you're seeing one too many zeroes.
About to hit the road from Seattle to Denver. Bought mine in September 07, and I'm up to 7100 miles. When I finish the roadtrip, it should be around 10k.
I haven't opened the hood since I bought it ... Is this a bad thing?
Check your oil and fluid levels frequently!!! Yes that is a bad thing in my book....especially if your going on a trip. you might even contact your dealer to see if you can drop by and have them check it out too before that trip. I was going to drive from Portland OR to Texas and took mine in and they went ahead and did a service for me and checked things out.
I changed mine at about 1,500 and it had lots of glistening metalic sheen to it from engine break-in. I changed it again at about 6,300 miles and sent a sample off for analysis. Some of the indicators showed that it was getting near the end of its life -- additives were about gone. While the viscosity was good, and fuel dilution wasn't too bad, it did have elevated levels of metals and silicon from break-in.
When you change it, I believe it is best to use an oil that meets the stricter European standard recommended in the UK manual. Look for ACEA A3/B3 on the back of the bottle. MINI dealers sell a MINI branded 5W-30 Castrol that is blended just for BMW. I paid $5.40 qt. for it. You can get the same stuff from a BMW dealer with BMW branding -- usually costs about $1 more.
This is one of the very few 5W-30 oils in the USA that meet ACEA A3/B3. There are some 0W-40 oils from other oil companies that are A3/B3 and should be OK. Most brands have one or two such oils. FYI, ACEA A5 is not better than A3. The main difference is viscosity at temp -- A3 is thicker. A1 is just an economy rating and not recommended for high performance engines (which the MINI definitely is).
The USA version of the owners manual only mentions an American oil standard that is much broader than ACEA A3/B3. I suspect MINI did this to avoid complaints about requiring esoteric European oils.
On one of these fora, I followed a link to an oil analysis test of extended change intervals. The followed several vehicles using different protocols. The findings noted two things I found interesting.
1) most of the engine wear was occurring in the first 3k after an oil change. Their conclusion was that even synthetics require a break-in; and
2) that changing only the filter at 5k and topping off with clean oil as needed made a big difference in the rate of contamination--it broke the upward trend and kept it lower even after it began to rise, again.
So, it looks like the answer is to change oil at what--7k-10k and consider changing just the filter at 4 or 5?
My dealer wasn't. He knew I wasn't going to wait a year for an oil change, and he knew I wasn't going to drive 90 miles to have it done at his shop. He actually gave me an oil filter to take with me. I don't see how a dealer can get snotty over someone caring for their car.
The drain plug on some MINIs requires a T50 Torx. Some require an allen (I think it is 8mm, but better check if yours doesn't use a Torx).
Remove the oil filler cap to allow air into the engine while the oil drains.
You need a 27mm socket and extension for the oil filter. Loosen the filter housing just enough to break the air seal and leave it in place so it can drain into the engine. Pulling it off immediately will spill some oil.
With an MCS you will need an 8mm socket to move the coolant tank. You can get the 27mm socket in there to undo the filter housing without removing the coolant tank, but it is too tight for reaching down there to lift it out. You don't need to remove the hoses from the tank. Just unscrew the one 8mm screw, unhook the tank from its plastic mountings, and lift it out of the way.
Be sure to remove the old copper washer on the drain plug (may be stuck to the bottom of the oil pan) and use the new copper compressible washer when putting the drain plug back in.
If you want to be precise about it, use a torque wrench to tighten the drain plug and oil filter housing. Torque oil filter cap to 18.5 ft. lbs., drain plug to 22 ft. lbs.
There's a thread with pictures around here somewhere that really helps. I changed mine at 3,000 and it was really easy, not much harder than any other car. My old oil actually looked pretty good, it was still rather clear and clean; to the naked eye anyway, but I felt better having new oil after the break-in period.
If most of the engine wear occurs within the first 3k after an oil change...shouldn't LONGER oil change intervals then be better? (of course within reason). Your #2 point seems logical, but why change at 7-10k and have the engine have to "break-in" the new oil again? Is Mini on to something with the 15k? (other than saving on "scheduled maintenance" costs during the first 36k?
I'm not a mechanic (and I don't even play one on TV!) so take this with that in mind.
Oil breaks down, it doesn't break in.
So that being said, (and assuming that's correct), by changing it BEFORE the computer says to change it, the oil will never get to the state where the OBD says to change it, right? So if you always changed it at, lets say 7500 miles, the OBD would NEVER tell you to change the oil?!?
Not saying you shouldn't have changed the oil, just trying to wrap my brain around how sophisticated and reliable a diagnostic tool the computer really is.
Let me look for that link.
I'll go back and try to find that report. They were talking about synthetic oil, in fact about Mobil 1, protecting better after the first 3k. This was based on their oil analysis results showing that contaminant growth slowed after the first 3k.
I've yet to see anything that substantiates the idea that oil breaks in.
