14mm lugs fit in a BBR Rk wheels
Old May 15, 2008 | 12:40 PM
Bhatch's Avatar
Bhatch
I am interested in a set of BBS wheels for the street for my MINI. Looks count too.
There is a set of RK localy, anyone know if i can get centering rings for those to fit the MINI 56.1 hub? Will 14mm studs fit on a BBS wheel normaly.
thanks.
Old May 15, 2008 | 12:44 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
I don't know about the RK's....but definitely check because 14mm lugs wouldn't fit in the BBS RM's that I just tried test fitting on my new ride.
Old May 15, 2008 | 12:46 PM
Bhatch's Avatar
Bhatch
Drill them out?
Old May 15, 2008 | 12:48 PM
Rally@StanceDesign
Originally Posted by Bhatch
Drill them out?
Definitely a possibility if your RK's end up being 12mm. It isn't too expensive...I just heard of a place only charging $20 a wheel to enlarge the holes.
Old May 15, 2008 | 12:52 PM
ScottRiqui's Avatar
ScottRiqui
You could also consider some 14mm-12mm conversion studs. A set of the studs + nuts costs more than having one set of wheels professionally drilled out, but less than having two sets of wheels drilled out, so if you think that these BBS wheels might not be the last wheels you put on your car, it's something to think about.
www.txwerks.com has the stud conversion kits.
Old May 15, 2008 | 01:08 PM
Bhatch's Avatar
Bhatch
I just relised i put BBR in the title. lol
anyway, should i expect issues with the center bore on these? VW is 57.1 so it should fit on the MINI, no?
Old May 15, 2008 | 01:16 PM
Rally@StanceDesign
Yah....if these are currently installed on a VW, the hubbore will be big enough to fit the MINI's hub which is smaller than a VW's.
Old May 15, 2008 | 01:19 PM
ScottRiqui's Avatar
ScottRiqui
Possible fly in the ointment here... Doesn't the BBS RK only come in a five-lug bolt pattern?
Old May 15, 2008 | 01:22 PM
Bhatch's Avatar
Bhatch
Rk come in 4 x 100. rare tho.
Old May 15, 2008 | 01:23 PM
ScottRiqui's Avatar
ScottRiqui
Old May 15, 2008 | 04:51 PM
Bhatch's Avatar
Bhatch
update, the wheels fit the lugs no problem. The clear is damaged on all the wheels but i will refinish them myself. I picked them up for 300 the set. Center caps are BBS originals. Wheels still have the german stickers on them.
4 x 100, 17 x 7J et 42. BBS RK.
17 lbs.
Pic.. weird chromish coating...probably was dipped once before and that is why the clear is comming off. That will be fixed later on this month.
:P
Old May 15, 2008 | 04:57 PM
Rally@StanceDesign
nice purchase
kazyn
Oct 25, 2019 02:34 PM
SosoMINI
Nov 22, 2015 03:17 PM
Colt45Magnus
Sep 7, 2015 10:47 PM
Mini'mon
Aug 16, 2015 04:15 PM
