R50/53 Check Engine light
Old May 13, 2008 | 10:08 PM
Under PSI's Avatar
Under PSI
Check Engine light
This may have been covered before but I couldn't find the response I needed by using the search so I'll pose the question. I did some work on my 2003 MCS recently and accidentally crossed some wires which caused a check engine or "service engine soon" light. I have corrected the problem but the light persists. Is there a way to clear the code or get the light to go off without having to take the car to the dealer? Thank you in advance and I apologize if this has been discussed ad nauseum but I couldn't find what I was looking for.
Old May 13, 2008 | 10:26 PM
Ancient Mariner's Avatar
Ancient Mariner
Depending on where you are, many big box auto parts stores will plug in a code reader, pull the code(s), and clear the codes. For free. Or you can buy a reasonably adequate OBD reader for $40 or so and do it your self.
-skip-
Old May 13, 2008 | 10:30 PM
Under PSI's Avatar
Under PSI
Thanks for the quick reply but the problem has taken care of itself. I took the car for a drive to make sure everything was ok and the light went off on its own so all appears to be well. Thanks again.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
