R56 E-brake
Old May 10, 2008 | 08:08 PM
postlapsaria's Avatar
postlapsaria
E-brake
I'm not sure if this is normal or not...I can give my e-brake a very very light pull and it clicks. It almost seems like this should be it's resting position, but it can actually go lower. I noticed this because sometimes I would hear 3 clicks when I park, and sometimes only 2. This means I was driving around for a while with that first click up...but there is no resistance when it clicks the first time. Is this the resting position?
Also, the chrome on the tip on the e-brake feels loose, is this normal?
Old May 10, 2008 | 08:15 PM
daemon2's Avatar
daemon2
no and no
Old Jul 27, 2009 | 12:41 PM
skimmilk's Avatar
skimmilk
Hey, I'm seeing this same thing so I'm bumping this up. Its very disconcerting to push down and have the handle not lock at the bottom most position. The brake still works and the light doesn't go on when pulled gently (e.g. 1/8 of an inch) to its first "stop".
Old Aug 20, 2009 | 06:59 AM
phong's Avatar
phong
I experience this as well. Is there a way adjust or tighten in such a way that the handle will lock at the bottom most position? Sometimes, it will be up like skimmilk said, 1/8th of an inch, and I would be driving.
While I'm pretty sure the e-brake is not engage, I don't feel like the handle should be in that position at all. It's just really annoying that the handle is that loose..you even hear the first click at that position.
Old Aug 20, 2009 | 09:08 AM
drewstermalloy's Avatar
drewstermalloy
Mine's been like that for a while too. I think we should get that checked out. Yesterday I pulled it up to park (my car wasn't in gear- I usually leave it in 1st but I forgot to) and the car started rolling backwards. I had to yank it up even further to get the car to stop. Is it normal for an ebrake to just stop working after a year?
Old Aug 20, 2009 | 10:53 PM
dooky's Avatar
dooky
I have the same problem too... i'll have the dealer take a look at it next week when I take car back for some other stuff.
Old Aug 20, 2009 | 11:13 PM
not-so-rednwhitecooper
The cable may be stretched. There is an adjustment on the handle under the boot.
gar56
Nov 15, 2016 06:41 AM
wlfman13
Sep 17, 2015 10:05 AM
OdzBodkinz
Sep 11, 2015 07:20 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
PGT
May 23, 2007 02:41 PM
