R50/53 dynoday depression lol
so i had a place that was doing a dyno day 3 pulls for $40 so i decided why not. now this is a floor dyno but i still see some problems
my adds, milltek catback, m7 ddm intake, m7 %16 pulley
now im not much of a dyno sheet reader but this looks not so nice to me
by the way its clickable
thanks
chris
thanks
chris
That's pretty bad actually. There could be a boost leak maybe?
after looking with in the last 10 mins i think i had one. the coupler wasnt on all the way on oneside, plus there is aloooot of oil in there , i know the oil is common but i dont think its ever been cleaned before 60k miles
i am also putting on a milltek header in a week or so , then ill go back and hit it again lol
so i cleaned it out and put the the conneciton back right and the but dyno says WOOOOW!
but does anyone know that would a boost leak cause it to dip and dive like that at the top and run out of air?
i couldnt tell but they make you stand back when they are running it , i did notice the the one coupler was tilted over on the larger port of the intercooler looked like this \ . so im thinking i had a bad boost leak, cause the car drives different now when shifting
like usually it would kinda jerk between shifts even shifting slowly, and now its more smooth like theres more power when i come off the clutch
There have been rumors of the 16% M7 Pulley causing some issues with belt grip (Something about the design) but I've never owned one or seen a car on the dyno with one, so I have no idea.
What size belt are you using with the 16%?
The 02-04 Tritec made 163 BHP.
The 05-06 Tritec made 168 BHP.
The bump was from a shift to the JCW Supercharger in 05 which had coated vanes.
The drivetrain loss on the MCS 6-Speed is typically closer to 10-11% though.
Anyway, it's all semantics, the numbers are a bit low, although not overly so.
should i have lost the 25+ hp on my first run in green though? i always wondered why it seemed to pull a little harder when shifting around 6k now i know why , hey the bright side is as long as i shift there i wont have to worry about over reving the supercharger
+1 on the need for a tune from Jan. The lines should/could be MUCH smoother. As far as the low #s, some cars are just stronger than others and there are a lot of theories on why. One thing for sure is that some versions of the factory tuning really sucks. Check out this link for the improvement that Jan's tune had on a MCS here in Rochester a few weeks ago.
https://www.northamericanmotoring.co...&postcount=168
id love to have jan tune it but the closest he has come to oklahoma since i got the mini was i houston wich is like 6 hour drive for me one way and i dont have any scheduled time off yet. also im debating on trading her up for an 05+ r53 with lsd
but i do understand that it wont be a straight arrow up , its the 25+hp dip i get right after 6k rpm
I for one think that someone did a lousy job at this dyno runs. The last two runs don't start untill like 2800 RPMs and you can see on the fist run (green one) that the torque is already pretty high at almost 2k. As far as the numbers go, they are to the wheels and they will always be lower than the crank HP.
As others mentioned it would help to know what the graph looks like for the stock MCS.
RobbyD
Jan 29, 2019 01:22 PM
