Suspension Longer wheel bolts/lugs for 15mm spacers?
Old May 10, 2008 | 02:34 AM
Maaij's Avatar
Maaij
Hi,
Anyone know where to get longer wheel bolts/lugs for 15mm spacers?
Maaij
Old May 10, 2008 | 12:57 PM
JDR's Avatar
JDR
http://www.radusadirect.com/
Old Sep 5, 2008 | 04:05 PM
JENGLAND's Avatar
JENGLAND
H&R sells longer bolts. You have to measure the factory thread length and the call them with the bolt demensions and they will have all the lengths that they make spacers for. 5mm, 15mm, 25mm
Old Sep 5, 2008 | 04:25 PM
oxtox's Avatar
oxtox
tsw
http://www.txwerks.com/servlet/Categ...el+Accessories
Old Sep 5, 2008 | 04:31 PM
quikmni's Avatar
quikmni
You will need 14mm x 1.25 pitch x 43mm long (stock is 28mm) with a 17mm hex head. +1 on radusa. However they are a gray color. radusa does have lug bolt caps.
Old Sep 5, 2008 | 06:12 PM
Derosi's Avatar
Derosi
Does the R56 need any changes to use 5mm spacers
The R56 uses 14x 1.25 but H&R does not seem to sell a 5mm spacer for the R56. Am I missing something or do they. Secondly who does sell a 5mm Spacer and does it work with the stock wheel hardware.
Old Sep 8, 2008 | 09:19 AM
JDR's Avatar
JDR
I'm using 5mm H&R spacers on my R56. And you will want 5mm longer wheel bolts.
Old Sep 9, 2008 | 08:05 AM
quikmni's Avatar
quikmni
My 15mm H&R spacers have large enough holes for the 14mm lug bolts. I am using them on a late 2006 R53 GP which has the aluminum trailing arm and 14mm lug bolts like the R56.
mikeyb74
Mar 21, 2017 12:30 PM
bradstyle
Aug 21, 2015 11:43 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
ti22fjc
Aug 9, 2015 05:49 PM
jcb-memphis
Aug 8, 2015 11:09 AM
