R56 2 Questions ------>
Old May 6, 2008 | 06:09 PM
FlyingZ06's Avatar
FlyingZ06
2 Questions ------>
1. Can I program my turn signals and outside lights, etc on my MC with no conv. package? My wife can on her Clubman with Conv package.
2. Alta intake...any good? Worth the money? Increase or decrease milage if my foot stays out of the throttle.
Thank you guys! This board rocks
I'll sit back and eat some waiting for the responses.
Old May 7, 2008 | 04:43 AM
FlyingZ06's Avatar
FlyingZ06
bump
Old May 7, 2008 | 04:59 AM
Arnbut's Avatar
Arnbut
the R56 lights and blinkers have some programming features that you can custom set.
And I'd find any CAI performance claims to be extremely slight alone. It does make the turbo influence more acoustically gratifying. And that will make you faster. Really.
Old May 7, 2008 | 05:01 AM
Oxybluecoop's Avatar
Oxybluecoop
You can program the number of blinks for the turn signals and turn the daytime lights off/on.
Old May 7, 2008 | 05:05 AM
Krut's Avatar
Krut
If you're going to put on a cold air intake - you may want to consider a DDM Works intake with the cold air diverter that actually uses the factory intake slot (I'm assuming you have a Clubman Cooper S). If not, an intake is going to only give you minimal result and a little more aural effect.
Old May 7, 2008 | 09:47 AM
FlyingZ06's Avatar
FlyingZ06
I can not get my car to do it. It is in the blinker lever where those features are at. I can do clock, check maint, etc, but no programming. Am i doing something wrong???
Old May 7, 2008 | 09:54 AM
Auto_Pilot's Avatar
Auto_Pilot
See below...EC Mag did a test on three typical bolt on mods for the MCS:
http://www.europeancarweb.com/tech/e...r_s/index.html
Old May 7, 2008 | 10:19 AM
FlyingZ06's Avatar
FlyingZ06
the sound of the blow off valve is cool though in other cars! Thanks for the link Auto Pilot!
Old May 7, 2008 | 10:37 AM
Auto_Pilot's Avatar
Auto_Pilot
No problemo...I'd also check out the mod section under drivetrain...there are many discussions going on right now about ECU and exhuast systems.
BTW...how is it like driving a Z06, and then jumping into a MINI ?
Old May 7, 2008 | 10:39 AM
Oxybluecoop
Start MINI
Press the stalk button until it says SET/INFO appears.Press and hold.
Keep pressing until CHECK/INFO appears.Press and hold.
Press 4 times until SET(the second one with a checkmark) appears.
Press and hold.
Now you should be at the settings.
The daytime lights(always on) is the fifth and turn signals the sixth
Old May 7, 2008 | 10:51 AM
FlyingZ06's Avatar
FlyingZ06
Start MINI
Press and hold.
Old May 7, 2008 | 11:03 AM
FlyingZ06's Avatar
FlyingZ06
I feel like the mini is a moped after the Z
Old May 7, 2008 | 11:30 AM
Auto_Pilot's Avatar
Auto_Pilot
Figured as much...but its the best handling moped on the planet.
Old May 7, 2008 | 02:17 PM
FlyingZ06's Avatar
FlyingZ06
So true! It's just so different. Z is a torque monster but handles the curves great, just a different feel.
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
twriter
Oct 2, 2015 03:14 PM
Carwash
Sep 15, 2015 02:02 AM
marc0011
Sep 10, 2015 10:04 PM
