Aftermarket pads and OEM rotors - no maintenance coverage?
My MA told me that if I replace the pads (to reduce dust) that the rotors are no longer covered by the maintenance plan. Seems when they replace the brakes, they do them as a set and have to return the whole set to MINI...
Is that consistent with what others have found?
I guess I could wait until my first brake job is necessary, get the new rortors, and THEN swap the pads...but my new white wheels may not last that long
It will make keeping them clean easier....but you will still have to wash them a bit....
Jason is right, the good news is that the Carbotech pads are the only pads on the market not using iron, which wears rotors faster, so you can get many more miles out of your OEM Rotors with CT Pads. PM me for more details.
if you go with the carbotech they make vary little dust. in a week you will have more dust on your tv then on your rims. so i recommend you go with the 1521 street pad and your rotors + pads will out last any thing uyou get oem
blackie
Oct 2, 2015 07:41 PM
squawSkiBum
Oct 2, 2015 09:21 AM
gmonde
Sep 8, 2015 06:37 AM
