Is TPMS transferrable?
Old May 1, 2008 | 07:58 AM
Auto_Pilot's Avatar
Auto_Pilot
I'm thinking of purchasing wheels that accept the OEM TPMS monitor for the wheels...Can I just take them off my STOCK wheels and put them on my new ones???
Old May 1, 2008 | 08:08 AM
FugitiveAI's Avatar
FugitiveAI
yes.
Old May 2, 2008 | 06:05 AM
Alex@tirerack's Avatar
Alex@tirerack
Beru sensor trasfer kits are $4.50 per sensor - new valve core and O ring.
Thats all you should have to change.
Call me if you need them
Old May 2, 2008 | 10:46 AM
rallymaniac's Avatar
rallymaniac
OK, I have another question. If you don't put the sensors on the new wheels, will you have the light on the dash and can it be disabled?
I'm not really looking to have the TPMS on my wheels especially when I don't use Run-Flats.
Old May 2, 2008 | 11:07 AM
Auto_Pilot's Avatar
Auto_Pilot
Me too...I check my tires pretty regularly...Disable TPMS FTW.
Old May 2, 2008 | 11:36 AM
lurch70's Avatar
lurch70
so wait ... can they be removed from the OEM set WITHOUT removing the tire from the rim? or will I have to spend $ to remove the tire first?
Old May 2, 2008 | 11:37 AM
Oxybluecoop's Avatar
Oxybluecoop
The TPMS light will stay on.I was hoping I could turn it off through the service reset procedure but it stays on.
Old May 2, 2008 | 12:47 PM
rallymaniac
So, I guess I'll have to resort to the "good 'ole" black electrical tape to fix the dash light issue
and while i'm at it I'll do the DSC and ABS light too
Old May 2, 2008 | 01:48 PM
Oxybluecoop
Did you try the disconnect negative battery cable press brake OBC reset?If that dosen't work you could try the service resethttp://www.mini2.com/forum/faq.php?f..._faq_reset_cpu
Old May 2, 2008 | 01:58 PM
rallymaniac
No I didn't try it yet since i'm still on stock wheels, but since i'm looking to upgrade it would be good to know if it's doable.
Thanx
Old May 2, 2008 | 02:01 PM
Auto_Pilot's Avatar
Auto_Pilot
Can't we just pull a fuse or something?
Old May 2, 2008 | 03:10 PM
FugitiveAI's Avatar
FugitiveAI
I wasn't charged for any transfer kit or told it was needed at America's Tires. Everything worked out fine.
TPMS is mandatory so disabling it is not easy by design. Why not just transfer them and forget about them.
... and yes you have to take the tire off the rim to remove the TPMS valve stem
Old May 2, 2008 | 08:14 PM
rallymaniac
and it's mandatory, why?
I don't like things being forced on me.
Old May 2, 2008 | 08:29 PM
Jim Ray's Avatar
Jim Ray
Because morons in Ford Exploders don't check their tire pressure, and can't tell when they are driving 75mph on a flat.
freckles81
Jan 15, 2017 06:33 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
Doc Pain
Sep 15, 2015 11:31 PM
PSU 98
Sep 11, 2015 11:20 AM
renchjeep
Sep 6, 2015 01:54 PM
